Question about Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 6 - No Impact
I have the same problem on an IBM Wheelwriter 6. Everything appears to operate properly, but there is no impact on the ribbon. I thought it might be a bad ribbon assembly, so I spliced in new conductors to the solenoid, but it didn't help.
  • Brian Blum
    Brian Blum Jul 27, 2009
    Could you (or another expert) possibly tell me where I could obtain such a teflon cap, what it's called, and how to go about replacing it? Thanks!
    President:
  • 2,306 Answers
The teflon cap on the solenoid end needs to be replaced.
Posted on Jul 27, 2009
  • Lexmark Master
  • 3,594 Answers
We sell the solenoid pad for 20.00 includes instrictionxs and shipping.
DickyO
Cleveland Business Machines
216-241-027
Posted on Aug 18, 2009
Wheelwriter 1000 does not type
More than likely the impact solenoid pad has worn out or came apart.
That pad is available from this website:
http://tsaworld.com/IBM/Typewriter/Wheelwriter
part number is 20-71
it is very easy to replace !
Nov 14, 2011 | Lexmark Wheelwriter 1000 Typewriter
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
Wheelwriter 6 stopped printing. everything works
Tou most likely have a broken print solenoid cap. We sell them for 20.00 includes instructions and shipping.
DickyO
216-242-0027
Apr 23, 2010 | IBM Wheelwriter 30 Typewriter
Why will the typewriter not impact with the paper?
You probably have a broken print solenoid cap. We sell a replacement with instructions and shipping for 20.00.
DickyO
216-242-0027
Apr 09, 2010 | IBM Wheelwriter 6 Typewriter
Typewriter keys only print half a letter
In general, there are two possible causes for this symptom. 1. The ribbon is not fully in front of the typeface at impact. 2. The typeface is not in the proper position at impact. Depending on the model of typewriter there can be different causes for these two conditions, for instance, on a manual typewriter, that has a manual shift key, it is possible that the segment which travels up and down when depressing the shift, is not in the proper position, thus , when the typeface contacts the paper, the curvature of the typeface does not match the curvature of the platen. This can cause the top or the bottom of letters not to print. Likewise on an IBM Wheelwriter, it is possible for the platen itself to be loose which can cause just the top of letters to print. Observe the ribbon lift position and installation. Check the hammer, printwheel, platen,
Nov 13, 2009 | Office Equipment & Supplies
The keys won't strike. I tried everthing and nothing works. You hit a letter and it just moves as iff you are hitting the space bar.
The impact solenoid has a rubber pad or cap on the tip that hits the hammer and it has probably broken off...needs the impact solenoid repaired or replaced and then the impact adjusted.
The part you need is available at
www.TSAWorld.com
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
I have a wheelwriter that won't type some punctuation (comma, period). I've changed the ribbon and tried different printwheels. Nothing solves the problem. Any suggestions?
The impact solenoid has a rubber cap that has worn down. Replacing the cap and adjusting the impact mechanism will get you back in operating order !
Jan 15, 2009 | Lexmark Wheelwriter 1000 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter
Is the hammer moving at all? There is a rubber part on the I think left side of the ribbon hammer, down on the side of the printer. This will adjust the amount of impact. I really doubt if
this is the problem, but worth a try to look at. This part and I think it is a blue slide will move up and down to adjust the impact. Possible lubrication and there is a large spring that actually pulls that hammer forward, check to see if this spring is OK. Other than that electronic problems such as main board, printer motors, etc. Does hammer move freely by hand? Also mechanical binding in the printer... GOOD LUCK.
Jul 23, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
372 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
