Question about Cell Phones
The touchscreen is not working. What can I do to fix it?
Touchscreen not working
replace batteries , and clean contacts batteries very well.
However if toruchscreen not work, you must open the r.control and clean the keyspads very well from oxide,etc use contacts cleaner and fix it. Try again.
If the problem persist, you have a Syscom faulty.
God bless you
Jul 30, 2013 | Marantz RC3200 LCD Touchscreen Remote...
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
http://www.sharc.net/gps_LCD_repair.htm
Mar 29, 2013 | Garmin nuvi GPS
Touchscreen not responding. Frozen
Two thing can cause this. If your unit is running firmware version 5.3, this version has a bug where the touchscreen will work for about 5 seconds then the unit will lock up. Updating the unit to version to version 5.4 will fix the problem. More info can be found here:
http://www.sharc.net/discus/messages/6/471.html?1337567850
http://www.sharc.net/discus/messages/6/469.html?1333569932
If you are running firmware version 4.9 or 5.4 and the touchscreen still does not respond, then the touchscreen will need to be replaced. On the Nuvi 7xx, the touchscreen may be soldered to the LCD display, so if you don't have any soldering experience, please have a professional replace the touchscreen. More info can be found here:
Mar 23, 2013 | Garmin Nuvi 760 Car GPS Receiver
Touchscreen does not work
unfortunately the LCD touchscreen is faulty. You must replace and dissasembly .
or go to the repair shop for fix it.
God bless you
Jul 22, 2012 | Logitech Harmony 1100 LCD Touchscreen...
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Touch Screen doesn't work at all. Can't use camera. How do we fix
Hi. Just a tip, try to do a calibration on the touchscreen. If it still does not work, there is a problem with your touchscreen itself. Hope this help. Goodluck
Jun 05, 2010 | Sony Handycam DCR-DVD505 DVD Camcorder
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
Jul 17, 2009 | LG Xenon GR500 Cell Phone
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Jun 22, 2009 | Tomtom ONE 3rd Edition GPS
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
