Question about RCA Televison & Video
My rca40la45rq the source menu keeps flashing off and on. How do I stop this from happening?
  • RCA Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jan 01, 2017
How do I stop the menu from flashing on and off on my desktop?
Keep the mouse pointer away for the bottom of the screen.
May 19, 2015 | eMachines Computers & Internet
Rca flashing the menu screen
a professional. Electronics go threw a self diagnostic to check for problems. it sounds like it's found one.
Jun 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 Jeep Grand Cherokee keeps flashing "Service 4WD switch".
You will probably find the oil level in the exchange box is low and the sensor is activating.
Jan 17, 2009 | 1995 Jeep Grand Cherokee
I have a Gateway FPD2275W monitor. When I turn on the computer the monitor flashes on for about 2 sec. and then seems to go into standby mode. Even the menu screens will not show up when this happens. When...
Your power supply may not be supplying the required electricity to keep your monitor on. Try plugging your monitor in a different electricity source. Your CPU may be drawing much power from the source and not enough is supplied to the monitor. You may plug the monitor directly to the UPS (uninterrupted power supply) if the cable end allows it.
Aug 31, 2008 | Computers & Internet
Apple ipod keeps flashing apple logo and cant switchit on or off
if u hav already sorted the problem ignore this
when your ipod stops flashing the apple hold menue+select then as soon as the apple starts flashing again hold select+play/pause for several seconds a white screen should appear, if this happens connect it to ur pc ur i tunes should then reconise ur ipod, u should then restore it
Aug 25, 2008 | Audio Players & Recorders
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
