Question about Dishwashers
CID60W12 - The powder doesn't disperse and is often solidified in the dispenser, even if the flap has opened. Manual says this may be because it's damp when it goes in but it isn't.Any other ideas?
  • 1462 Answers
SOURCE: Powder not dispersing
possible the wash arms are not rotating - a common cause of powder not being taken. check by opening the door when in use and look to see if arms rotate. if not, then remove the arms and clear the jets especially the angled jets at the end which cause the arm to rotate
Posted on Jun 21, 2007
  • 1894 Answers
SOURCE: Miele G1270SCVi
If the detergent cup doesn't open, check the detergent cup, the bi-metal switch or wax motor, and the timer. Make sure that no dishes are blocking it from opening.
The cup that holds the detergents can get caked and gooped up with old detergent. You should try to clean away any old detergent. If you can't clean the detergent away, you should replace the cup.
The bi-metal switch is activated by the timer and is an electrically operated device that bends when electricity is applied to it. It uses two different metals that are bonded together. As they warm up, they expand at different rates causing the metal to bend. The degree of bending can be set with a high degree of precision. Many devices use the bi-metal switch. A lot of newer dishwashers use a wax motor instead of the bi-metal switch. The wax motor has a wax block that gets heated up when the timer sends electricity to it. The wax expands as it gets heated up, and it pushes a plunger that opens the detergent door. Depending on how your dishwasher is wired, the switch may be wired through the motor circuitry or through the heating element. If the heating element is broken, there will be no electricity to properly activate the switch or heat the wax block in the wax motor to open the cup. If the motor doesn’t let enough electricity through its circuit, the bi-metal switch won't operate properly, or the wax motor wax block won't get heated up to expand and push the plunger.
On many dishwashers, an actuator arm links the timer to the detergent cup. When the timer reaches the correct time of the cycle, it activates a lever that opens the cup. If this link is broken or in any other respect faulty, the cup will stay closed, and won't let the detergent into the dishwasher. Check this linkage and either fix or replace it.
Posted on Aug 07, 2008
SOURCE: soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Posted on Jul 26, 2010
jnchahn
  • 252 Answers
SOURCE: the detergent dispenser doesn't seem
Soap residue on the spring latch door. Try cleaning the soap around the hinge.
Posted on May 14, 2011
SOURCE: Hotpoint FWD70 - dispenser flap not opening. My
This has hapened to me twice. I am no expert so treat the following with caution. This is what has worked for me.
1/ I sugest you check the dispenser solenoid - it should be about 1.65K. If it is open circuit buy a new dispenser assy - about £29.00 - try http://www.hotpoint-spares.co.uk/dispenser-assembly-for-fdw70p-p-121945.html. This sorted my first failure.
2/ My second failure occured 18 months later. I removed and checked the solenoid as above. I found the resistance was OK so I put it all back together and it now works OK so I can only think that there was a bad connection at the dispenser which all the disconnection / reconnection sorted out (two connectors at dispenser).
3/ A word of warning - take especial care not to damage the seal aroud the dispenser - this seal is somewhat delicate.
4/ If all else fails, try an expert !
Posted on May 24, 2011
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
What to do if your Dishwasher isn't cleaning well...
Check the following when experiencing poor cleaning results:
- Dispenser (Where you put the Dishwasher Tablet or Powder)
Make sure that the flap holding the powder in is not loose.
Make sure it is dry before ever putting in powder.
- Dispenser (Flap Type)
To check if it is still opening for the Spray Arms (Spray Arms need to throw water on the Powdered contents to wash the dishes) - Put the Dishwasher in a cycle, and halfway through the cycle, open the door. if it has not opened then maybe the solenoid/actuator needs to be replaced.
- Program Selector (Not the component, the function selected)
More time consuming programs are more likely to wash more effectively, try selecting these with a higher heat setting instead of your usual programs like quick wash etc..
- Machine overloaded.
Make sure the baskets are not overloaded with dishes, mugs & glasses as this can make spray arms find it more difficult to clean between them
- Soap
In tests regarding powder vs. 3 in 1 tablets like "finish", it has been shown that powder gets dissolved much better, this is because the 3 in 1 tablets are designed to disintegrate on certain heating phases of only a select few brands of Dishwashers. So if you are unsure, or experiencing undissolved tablet - Use powdered dishwasher soap instead.
- Salt container
Refill the Salt container every 3 - 4 months depending on how frequent you use the dishwasher
- Spray arms
These can often be clogged with dirty water etc. clean these with toothpicks and pressured water.
- Filter
Clean these every time after a wash, usually found at the bottom of the dishwasher where water drains away.
- Over the counter products
These can be bought at Appliance spare outlets or even at some supermarkets. Use these as the directions indicate.
- Element (Last step if not improved)
Replacing a element is usually a last option, if no improvement was experienced by doing all of the above it could be that the element is not heating at the right temperature, or not heating at all.
Either replace this yourself (with various degrees of difficulty depending to the Make and model) or get a qualified service technician to do it with you.
Hope this helps :-)
If you found this helpful, please vote accordingly.
on May 10, 2011 | Dishwashers
The machine does not drag the chemical powder with water
Check you havn't got a powder blockage in the powder dispenser tray. Powders can solidify and choke up the pipes at back of tray.
pete
Nov 08, 2010 | Washing Machines
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Simpson brand dishwasher won't disperse detergent tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
Feb 18, 2009 | Dishwashers
Kenmore 16163 401 dishwasher
The dispenser flap should be spring loaded to spring open if the lock is released. If it doesn't spring open you should make sure that the spring is placed correctly on the hinge of the flap - if it doesn't spring open it won't get the detergent where it needs to go during the wash. We had the same thing.
Dec 17, 2008 | Kenmore 24 in. 16163 Built-in Dishwasher
Soap dispenser flap not opening
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Miele G575 Dishwasher
If the water level is not adjusted at the right level
(see Miele G 575 manual page 29),
the flap doesn't open at the right circle,or doesn't open at all.
(Cause of the low water level the machine makes more noise!)
======Now shut down the power for the machine!!!=============
To adjust the water level new,you have to open the shield(2 screws) under the
main door.(enginen compartment).(You don't have to move the machine!)
On the right ,right,right,hand side,there is a 6 cm round beige plastic box.
(the first thing you see to you right and very easy access)
Only one black water hose(about 1cm=1/4inch) and a few wires are going into this box.
This is the water level adjustment box.
In the middle of the beige plastic box is a beige plastic screw
to adjust the water level new.Turning it clock vise ,increasing
the water level.
(For the right water level,see page 29 in your G575 Miele manual)
The water level hasn't to be super price.Just in about and enough.
(It seems that the rubber membrane in the water level unit ages
and therefor it has to be readjusted after a longer time)
Aug 27, 2007 | Dishwashers
Jun 21, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
Top Dishwashers Experts
