Question about JVC HR-XVC19S DVD Player/VCR
Manual for jvc xvc19
Where can I view a manual for the jvc xvc19 The dvd is installed and playing, but no sound or picture on tv
How to get picture and sound on jvc xvc19
It seems there could be a problem with the tv-dvd link. http://resources.jvc.com/Resources/00/01/00/LPT1086-001A.pdf the dvd manual can help alot
Jan 01, 2017 | JVC HR-XVC19S DVD Player/VCR
Can record on DVD disc will not play on DVD player
Make sure the materials you're trying to record onto the DVD
is not Copyrighted. Try to record a normal TV program onto your
VHS, transfer it to your DVD and then play it. See if that will
work. A VHS movie is usually Copyrighted and Protected by
Macrovision. The picture output can be displayed on a TV set
for viewing but is scrambled black to a DVD Recorder.
Jul 16, 2011 | JVC DR-MV100B DVD Recorder/VCR
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
Playing a dvd and cant get picture just sound
Change the channel down past 02 until you get to INPUT 1, AUX, INPUT 2, ect. One of these will show the picture. Check your wiring as well. The RCA (audio/video) jacks must go from the OUT connectors from the DVD to the IN connectors for Video or Input 1 or 2. I know this sounds remedial but I get them mixed up when in a hurry since it is usually dark and they are hard to see. Good luck and thanks for allowing me to help you. Please rate me if this was helpful.
Jul 26, 2009 | JVC AV-27230 27" TV
No picture on dvd but picture on tv only sound comes out on dvd
Could you try to set your channel to 2,3, or 5 when viewing video from dvd. Or try search which channel will the video and audio will sync in tune. I think this is an old tv.
Hope this one helps.
Apr 07, 2009 | JVC AV-27530 27" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
JVC HR-XVC19S DVD Player/VCR Logo
29 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
