Lens in eyepiece is loose and turns sideways
SOURCE: Konus Spot 80
I understand your frustration!
Please try to contact their US service center:
KONUS USA CORPORATION
7275 NW 87th Ave.
MIAMI FL 33178
tel. +1 305 5925500
fax +1 305 5926255
SOURCE: what lens do i insert into scope to view the moon
The moon is big so use the 25mm. The Barlow will have a multiplication marking on it 2x 3x etc. A 2x Barlow lens will effectively double the power of the eyepiece you are using. Do not use the erecting eyepiece for anything other than land viewing. Erecting eyepieces generally reduce the amount of light reaching your eye and thus reduce brightness of the faint objects in the sky.
So basically just place the 25 mm lens in the focuser and point the scope at the moon and you will be amazed at what you can see and how bright it is.
SOURCE: loose dirt on mirror Meade Lx6
Nope, the dust is on the webcam sensor. The telescope mirror is too far away to influence the image. Most modified cameras have no window to keep dust off the sensor's cover. A camera lens cleaning brush works fine. Also, some cameras have 'hot pixels' that are defects in the sensor, and are permanent.
SOURCE: I own a Pentax PF80-ED spotting scope with a
You do not get spare parts for this spotting scope in internet.Try in local camera shops of your place or else no other go you need to send the scope to service department only.
Thank You
SOURCE: I have a new-in-box Konus Motormax 130mm 1796 I
Contact a regular DEALER for this scope and see if they have one. You may just have to look in a well stocked hardware store for something you can use to mount the scope on the tripod.
Testimonial: "Thanks."
