Question about LG DLE5001W Dryer
Hoe too put a lg dle5001w door back together - LG DLE5001W Dryer
Does my LG DLE5001W dryer have a reest button ?
Check your power panel for a tripped circuit breaker. There will be two breakers with their handles joined. Sometimes one will trip but not both. This causes only 120 volts to be applied to the dryer which runs everything but the heating element. Replacing the breaker will solve the problem
Nov 21, 2016 | LG DLE5001W Dryer
I have a 2 year old LG DLE5001w dryer. It stoped heating heater element replaced on 11/21/14. Worked 2 loads stopped heating, replaced switch, worked 3 loads stopped heating replaced thermostats. Did
Most Dryers has a thermal switch that when the air flow gets so hot it will shut down the dryer until it cools down or on some models the thermal switch has to be replaced .. The most common problem to cause this is a restricted air flow somewhere in the exhaust of the heated air causing the dryer to reach too high of temp, which could cause a fire .. Hope this information is help full......
Dec 29, 2014 | LG DLE5001W Dryer
Remove front cover
Disassembling the LG dryers, electric and gas, is best described on You-Tube.
Jul 16, 2014 | LG DLE5001W Dryer
LG DLE5001W Dryer Lights Up but won't accept programming commands or operate
I would guess new belt is slightly misrouted. From front, belt comes down left side of drum and goes around belt tensioner and then back to the motor pulley. Without the tensioner pulled to the left, the safety switch will still be tripped. Pulling tensioner to the left completes the circuit to the motor and allows motor to run.
Jun 23, 2017 | LG DLE5001W 7.3 CU. FT. FRONT LOAD...
I have a LG Dryer Dle5001w that is 3 years old. It no longer will dry clothes on timed or sensor options in a reasonable amount of time. One average load takes 3 hours to finish. It does heat well and...
have a repair man check to see if the sensor that turns on the heat in timed or sensor mode has a good connection or needs replacing if that doesn't work it may need a new computer
Feb 07, 2014 | LG DLE5001W Dryer
Holmes heater
buy another one... take it apart making notes... put it back together... test it... if it works, you probably will be able to reassemble the one you have shown...
cmilton111
Oct 27, 2013 | Heating & Cooling
Lg dryer dle5001w keeps running
Hay Donald , sounds like the relay on your control board is stuck closed .replace control board, good luck APPLIANCES R EN
Feb 28, 2013 | LG DLE5001W Dryer
Lg dle5001w flowsense
Replace the timer switch, check the wires to it and to the heating element!
Dec 25, 2012 | LG DLE5001W Dryer
DRYER WON'T START
it may be in the start button or it may be a sensor on the door is not working properly. you also may have a breaker issue. on alot of dryers you have a 2 pole breaker and if you lose one side of the power at that breaker it can lose some of its capacity to operate certain functions on your appliance
Feb 17, 2012 | LG DLE5001W Dryer
LG DLE5001W Dryer Logo
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
