Question about GE Refrigerators
I Have a GE GSS25QG Refrigerator water dispenser solenoid leaks. No water but can hear it making noise. A little water at the very bottom of fridge side. How do I fix?
fanny
  • 146 Answers
SOURCE: Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Posted on Nov 03, 2007
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
SOURCE: GE side-by-side refrigerator not dispensing ice or water
could be the dispenser circuit board.
Posted on Aug 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
SOURCE: jenn air jcd2389g side by side refrigerator water leak
Here was my solution. When I had the water filter in water would dispense from the door as usual, but at the same time fill (or overfill) the ice maker. When I put the dummy plug back in the filter spot.....no leak.
Posted on Oct 15, 2011
Switches on kitchen aid refrigerator dispensers not working.. ice maker is working, but will not dispense ice or water
Sounds like the water has been turned off, or the solenoid valve (located at water entrance to fridge) has failed. you should hear a solid snap from that solenoid when water is called for by pressing the dispensing switch. You can test the solenoid by unplugging the fridge and measure the resistance across the solenoid terminals. If it measures 200-500 ohms it is ok. if it measures open the solenoid has failed and needs to be replaced.
Sep 18, 2014 | KitchenAid Refrigerators
GE Refrigerator Model GSH22SGRBSS NO WATER TO THE FRONT DOOR DISPENSER. ICE OK
Generally, the path to the water dispenser is as follows: water comes in from the wall, goes through a solenoid (valve), and through some tubing to a reservoir behind the fruit and vegetable compartments. From that reservoir, more tubing goes down under the refrigerator, then up near the bottom of the door hinge of the door that has the water dispenser.
First, listen for if there is a water running sound when you try to use the water dispenser. If there is not, then most likely there is no water coming from the supply at the wall, or the main solenoid where the water comes in is not working. If ice is being dispensed, you know that the switch that you press with your cup is good, but that doesn't mean that water is coming in to make new ice. It could be just existing ice being dispensed.
If you DO hear a water running sound, then something is leaking, possibly onto your floor. Follow the path of the water in the first paragraph to locate the leak. Could be that some tubing came off, or burst.
Nov 08, 2011 | GE Monogram Side by Side Refrigerator
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
My GE side by side fridge doesn't dispense water.
When you press the handle, do you hear/feel a click?
Is this just starting to happen after a power outage?
Is the ice machine making ice? Dispensing?
Do you have/know how to use a multimeter to check voltages at the water valve solenoid?
Thanks!
Feb 21, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Load noise when I turned on water for ice
I assume it was the water dispenser. It has a solenoid on the water inlet valve which can stick. Is the noise coming from the back where the inlet valve is.
Jun 30, 2009 | GE Profile Stainless Bottom-Freezer...
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water from dispenser in fridge door
most likely the water line is frozen in the door. try letting the freezer door stand open for awhile to allow it to thaw out. good luck peyton
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
