Question about Fishing
Quantumex400 fishing reel - Fishing
  • Fishing Master
  • 3,498 Answers
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
SOURCE: How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
Posted on Feb 26, 2009
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
spenningreel
  • 4 Answers
SOURCE: How to buy a fishing reel
Best Spinning Reel Review & Buying Guide 2016 Best Spinning Reel Review Buying Ultimate Guideline
Posted on Nov 15, 2016
How do I choose the best fishing reel size for my needs?
Small Spin Reels:
Spinning Reel Size: (1000 or 10)
  • Suggested mono: 1-2kg (2-4lb)
  • Suggested Braid: 4-8lb
  • Common Applications (Guide only): Small fishing reel mostly suited for light fishing in lakes, rivers, bays, harbours etc.
  • Popular for fish type (most common species): Bream, Trout, Whiting.
Choosing a fishing rod to go with this size reel: - As the 1000 or 10 sized spinning reel is quite small, a rod you would typically pair this reel to is one with a length of around 6-7 foot that has a fishing line rating of anywhere between 1-4Kg.
Spinning Reel Size: (2000 or 20)
  • Suggested mono: 2kg-3kg (4-6lb)
  • Suggested Braid: 5-10lb
  • Popular for fish type (most common species): Bream, Trout, Whiting, Bass, Flathead, Perch, Luderick.
Choosing a fishing rod to go with this size reel: A 2000 or 20 sized reel being a quite small reel ideally will suit a fishing rod between 6ft - 7ft 6 inches in length that has a line class rating somewhere between 2-5Kg.
Medium Size Spin Reels:
Spinning Reel Size: (4000 or 40)
  • Suggested mono: 4kg-6kg (8-12lb)
  • Suggested Braid: 8-20lb
  • Common Applications (Guide only): Medium fishing reel mostly suited to lakes, rivers, bays, harbours, light offshore boat fishing etc.
  • Popular for fish type (most common species): Snapper, Morwong, Tailor, Mangrove Jack, Cod, Bone Fish, Barramundi, Mulloway, Drummer.
Choosing a fishing rod to go with this size reel: A 4000 or 40 reel is where you start to gain a little size so this sized reel will generally suit medium action classes of rods in the 6ft-7ft (barra/snapper style rod) with a line class of around 4Kg-10Kg or in an 8ft-10ft (light surf) rod with a light line class rating of around 3-5Kg. Remember this is a guide only to suggest common applications so by all means you can use this reel for several other applications as well.
Apr 09, 2018 | Fishing
Tip
Left-Handed Fishing Reel Advantage
5 Best Left Handed Fishing Reels Overview
So, what is the benefit of left-handed fishing reel? Why are we even talking about left-handed fishing reel advantage when we are concerned about the best spinning reel models? There are reasons and you are going to know why!
Best Left Handed Fishing Reel Review Buying Guide 2016 2017
on Nov 24, 2016 | Fishing
Parts for zebco quantumex400
http://www.mikesreelrepair.com/
Jan 01, 2017 | Fishing
How do I change handle from left to right handed
The easiest way is to turn the rod over. Not all reels are ambidextrous. If there is a similar cap on the other side of the reel, then it is likely. You have to undo the screws and split the casing, and then turn everything around. A local fishing tackle shop would do it for you free of charge.
May 08, 2016 | Fishing
How do i repair a fishing reel model r2f cf-702/mhc
R2F Fishing Reel Parts‎
www.when.com/R2F+Fishing+Reel+Parts‎
Explore R2F Fishing Reel Parts
Discover More on When.com!
Sep 18, 2015 | Fishing
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
Aug 21, 2014 | Fishing
Instruction manual for b-mag 1000
Shimano b-mag 1000 fishing reel manual -
momot-guitars.com/en/.../shimano-b-mag-1000-fishing-reel-manual?...
Jul 22, 2015 - Download Shimano b-mag 1000 fishing reel manual >> Download ...
May 05, 2014 | Shakespeare Surf Fishing Rod and Reel...
Fishing Logo
527 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
