Question about Dryers
The dryer keeps tripping my fuse i changed the cord but it continues to do so
Ijijiooi
Posted on Aug 25, 2011
  • 55 Answers
It sounds like you have a dead short on the inside of your dryer. The element is shorted out, a wire is burnt or the plug on the wall is bad. These are the only things that could cause it. I would personally start by replacing the wall plug and trying that. This is your least expensive and easiest job to do yourself.
Posted on Jul 23, 2009
No heat but have changed heater and themostats plus water light on but no water in tank
make this test and fix it. Merry Christmas
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 17, 2013 | Hotpoint Dryers
Heat starts and then dies and never goes back on but dryer keeps spinning
follow this steps and fix it. God bless you
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
Oct 01, 2013 | Whirlpool LGR6611L Gas Dryer
Change a four prong cord to three prong cord, dryer heats, turns but does not dry, vents have been cleaned
test this steps and fix it. God bless you
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2ab3IwDXf
Jul 31, 2013 | Frigidaire FEQ332E Electric Dryer
Dryer portion on my stackable does not heat up.
Hello there:
please try these solutions and keep me informed on how this is going for you ok
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Kenmore 88752 Top Load Stacked Washer /...
My dryer doesnt heat at all! Goes straight to
If your dryer doesn't heat, check these:---- Power from the house:------ Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.----- Heating element:------- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.---- Thermal fuse:----- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)---- Wiring:------ A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.-----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 19, 2010 | LG DLE5977 Electric Dryer
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
Check the following to address this issue.
1. No power to the dryer(If you have power, skip to the next possible issue)
2. Heating element
3. Thermal fuse
Jul 18, 2009 | Dryers
Kenmore heavy duty. its working properly but not heat
Heating element:
Thermal fuse:
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
My Kenmore electric dryer model# 64652400 is not heating.
Hi
Fuses Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Please revert for further assistance and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Mar 16, 2009 | Kenmore 64652 Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
