My Linsar TV dvd combi has sound on TV but not when playing Dvd. I have checked all of the obvious such has volume and mute button and the manual but no joy
bmwrider
  • 215 Answers
SOURCE: Hooking up external DVD player
If you only have the one Audio/Video or AV input then pop into a TV store and buy a cheap AV switch. Plug your Dish Box into one set of inputs and your DVD into the other. Then run another lead from the switch box to the TVs AV inputs. That way all you do is match the switch to whatever it is you want to watch. If your TV does have two AV inputs just run each unit to a set of inputs and change the TV to AV1 or AV2 depending on which you want to watch and which unit is connected to which AV input. I hope you understood that :-) BMW
Posted on May 27, 2006
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
Danmart
  • 291 Answers
SOURCE: Sound form Bush TV
It could be several problems, I'll share with u a couple. All of them need a tech.[technician]
Your volume control works by adjusting the voltage\current to the speakers. The VOLUME CONTROL could be damaged\fixed at a point [even if you are raising\lowering] at high volume.Sometime the control has a crack ********\********* in such a way that the volume arm won't go past crack[see above] on HIGH volume.
The audio IC could be shorted in high volume. Sometimes the audio IC is PART of a 64 (sixty-four) pin ckt. How do u test for that if u are not a techo'
Let someone take a peek at it.
Posted on May 12, 2008
SOURCE: bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different countries.you can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Posted on Nov 25, 2008
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
hi my bush modle is btv183dvd\c i live in iran but i didnot buy this in iran well i listened that this modle has code ( if you kepp the negative switch volume on your tv & in that time push & keep the number 6 on controler ) you can see very much codes please dont change thoese
but i changed thoese and know i cant search for channel and it cant show that channel that befor time show that
please help me thank's
im armin
Posted on Jun 28, 2009
Why is there no sound on itv on my linsar tv? How can I get sound?
un mute it, sum tv's require an external tuner for sound. if you don not have a built in tuner go back to the house you took it from and get the rest of the parts you unpaged.
Apr 12, 2015 | Linsar Televison & Video
I have dvd tv combi and the sound will not go above 30. I have tried going into settings and the volume but nothing happens.
follow this steps and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 25, 2013 | Televison & Video
Have lost sound on my dish TV and mute button is not on
Is there sound using the set top box? Try a different remote if possible. Last but not least, Call Tech Support.
Oct 14, 2013 | Televison & Video
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
Jul 21, 2012 | Televison & Video
I have an Neon 19" TV DVD combi. There is an icon showing in the top left hand corner that looks like a mute sign with a red cross through it. I cannot make this disappear and as a result i have no sound....
Tries look for the tv manual control buttons.The volume button + - push the + to increase volume a bit,it will get out of mute.U can do the same with ur remote control volume control + -.
Sep 14, 2010 | Televison & Video
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Dvd sound isn't working
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
Sep 08, 2007 | RCA DRC8300N DVD Recorder/VCR
No sound,volume bar works
Sounds like it may be something you did. Have you checked to see if you accidentally put the sound on mute? Try hitting the mute button on the remote control. Also, if the TV has the option to turn of internal speakers (which you would likely find in the menu under audio settings if it does) make sure they are turned on. If these checks fail then we have an electronic problem to deal with.
Aug 31, 2006 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
