Question about Health & Beauty
The motor of crazy fit vibration massage does not work, only the panel lights light up all functions in panel are normal, but motor is nit strating
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
  • 108 Answers
SOURCE: Only one function works on my main panel
If the problem is that only one button (normal cycle) works when you press it and none of the others do, then you have most likely a bad keypad, but possibly a bad circuit board. It's difficult to say without knowing which model of dishwasher you have.
The repair is not really that difficult, but you should probably order both from someplace with a good return policy, then change the keypad first and see if that works. If it works, return the circuit board. If it doesn't work, put the new circuit board in.
Posted on Mar 09, 2009
roadtech7
  • 297 Answers
SOURCE: nordictrac 2500 problem: when dead man key is
You have it in DEMO mode, your manual will show you how to disable this feature.
Have a good new year!
Posted on Jan 02, 2011
SOURCE: Crazy Fit Massager Body Vibration
My machine is not vibrating as it should
Posted on Apr 05, 2011
SOURCE: manual for crazy fit massage
I have a Crazy Fitmassage but I dont know how to program the machine,help me
Posted on May 18, 2011
I have a crazy fit power massage machine and it cuts off when u turn up to level 6 .
Why not try the contact at the web page for the machine. They may have an answer.
Crazy Fit Vibration Plate for Home Crazy Fit Massage
I noticed the following article as I was Googling information about this machine. It probably predates this machine. Just something to think about.
Shake your way to skinny Experts fear risks
Sep 03, 2017 | Washing Machines
Without knowing what vehicle you have it is not likely anyone can advise you.
Nov 23, 2014 | Cars & Trucks
Why does my crazy fit massage vibrates violently as soon as you turn it on
It would be helpful to have more detailed info, but I;ll take a stab
at it... Usually, when a motorized device vibrates voilently (more
than designed to), it is due to missing parts or being out of
balance in the recriprocating mechanism. Try going over the
machine, again, with this in mind. If you can find another working
machine, make a comparison (perhaps in a local gym?)
Good luck !
Aug 19, 2014 | Sunny Health & Fitness Crazy Fit Massage
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
May 10, 2012 | Sunny Health & Fitness Crazy Fit Massager
Hand held rechargable masager recharges but doesn't not vibrate when the button is pressed, the red light does not turn on either. The red light only goes on when it's recharging
Possible that the supply to the motor is cut or the motor is faulty or the switch has failed.
you have to remove and check the three possible faults, perhaps inthe process of vibration this can make wires break off contacts.
Sep 21, 2010 | Homedics Rc Quad Quad Extreme Rechargeable...
Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
Aug 30, 2010 | Sport & Outdoor - Others
I carent put the wire throught my pro power multi gym
my crazy fit massage fusion vibration plate machine wont work,how do i fix it
May 27, 2010 | Pro-Fit Exercise & Fitness
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
