Question about Refrigerators
How do you remove the salad drawers from bottom of Bloomberg fridge SSM13511
  • 958 Answers
SOURCE: Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Posted on Sep 07, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
co7196
  • 3433 Answers
SOURCE: the fridge on my bosch fridge/freezer keeps freezing all my food
This, as with the on off complaint on a bosch, sounds like your thermostat is n't paying attention. Turn it up, then slowly down and feel for any irregularity. If there is looseness or rough, like hsngin up its the thermostat. At least we know the bulb goes out when you close the door. Good Luck
Posted on May 25, 2009
  • 323 Answers
SOURCE: water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Posted on Nov 07, 2009
SOURCE: I keep getting water at the bottom of the fridge, under salad boxes. freezer is below fridge
behind back panel of fridge on the inside is a drain tubeat bottom, remo that runs from freezer to evaporator pan under fridge, either ice or a piece of trash has probably clogged the drain remove panelandsee if debris is visible if so remove it if not visible use a strightened wire coat hanger and snake out the drain tube this should take care of your problem
Posted on May 12, 2012
BEKO CG964 fridge/freezer - base of fridge flooding with water underneath salad drawers
I had the EXACT same problem. I've just used a wire coat hanger and pushed it through the hole that the plunger couldn't impact and all the water drained out perfectly! Problem solved!
Jul 02, 2012 | Refrigerators
I have a zanussi ZI 920/9K and the fridge has water under the salad drawer every day but the drain hole is not blocked - what else might it be?
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Jul 05, 2010 | Zanussi ZI921 / 8FF Bottom Freezer...
I have abeko ap930 ,everything in the bottom 2 drawers in the fridge keeps freezing anyone know how to solve this?
it could be door seals ,not fitting tight all round(an air leak in the bottom seal will encorage ice to form on the floor) thermostat turned up to high(fridge temp should be plus 2 to 5c not lower or salad will freeze.
or a faulty thermostat.
pick one.
leave feedback
ta!
Jun 17, 2010 | Refrigerators
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Have set fridge at 46 degrees yet salad veggies still freeze in the compartments. How can I fix this?
Remove the bottom drawers and locate the vent small round hole. cover it with a piece of sturdy tape...problem solved.
Nov 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
WATER LEAKING IN MY FRIDGE
OK I will try to help but I see the date of your post is close to 2 weeks ago. Sea Breeze
Jul 07, 2009 | GE GTS22KBP Top Freezer Refrigerator
The fridge on my bosch fridge/freezer keeps freezing all my food
Dec 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
tnx 4 using fixya,
drcool
Sep 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
