The screen is wider at the bottom then at the top of the screen, how do I fix this? Thanks
How do you fix prius defrost
I can't say if yours is broken or not but I know mine reacts similar to yours. I put it down to the top screen being glass and the bottom one being perspex/plastic. I also notice that the gap between the elements is wider on the bottom screen, so maybe the perspex heats up quicker than glass?
Aug 28, 2014 | 2009 Toyota Prius
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
How do I change it from wide screen to regular? I have a black area above and below the picture.
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
My new side by side refrigerator doors are to far apart. The gap between the doors is wider towards the top then the bottom. How wide should the gap really be and can I adjust the doors so they are...
If you loosen the bolts that hold the hinges on, there should be a small amount of play that will allow you to square up the doors. The gap between the doors should be just wider than your fingers, so they don't get pinched.
Nov 29, 2010 | Refrigerators
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Picture is only in middle of screen, top and bottom of screen is blacked out
If you are watching widescreen format movie or tv programming on a non-widescreen tv, that is how it will appear. The widescreen is a wider picture so to show it on a less wide screen, it has to shrink down to fit. and leave blank space top and botton.
If not, sorry.
Sep 12, 2009 | Toshiba 36A40 36" TV
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
Picture not square
keystone should help in your opinion. adjust the keystone and the picture should be a square then.
Oct 28, 2008 | Hitachi CP-X275 Multimedia Projector
Unable to view fullscreen in hdtv
That is the way HDTV is viewed on many screens as a wide fromat. So you will get top and bottom non-viewable areas. It is the width that gives the full imagery for that format. To have the screen filled you would get a standard 4:3 format like standard TV. HD is a 16:9 format so it is much wider.
Sep 22, 2008 | Panasonic CT-32HX40 32" TV
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
