Error cod E18-4 is showing on Mnet channel 101
ERROR COD C6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera FS-1118 Printer
How do i connect more then 1 tv to my mnet decoder
You need a signal splitter from the decoder to the TV(s). But there will be a problem with that. Signal degradation. and channels you want to watch with 1 decoder. Your service provider may come a calling.?? You are aloud 4 TVs per house hold as far as I was told. Good luck.
Jun 02, 2013 | Televison & Video
HD channels 101 102 103 on Panasonic Viera coming up as no signal what do I do to restore them
You might need to adjust your antenna and reprogram your channels. It helps to reprogram every once in a while anyway, because new channels are always coming out.
Mar 15, 2013 | Televison & Video
Error101(net::ERROR-CONNECTIONS-RESET)Unknown error
i use the google chrome & when i want to go to orkut or any other option it shows the web page is not available & also show error 101
Oct 01, 2009 | Google Chrome
I loaded the update for my blackberry and got an error jvm error 102 and now the phone will not charge or turn on i have tried a new battery and that does not work. It does not show like its charging or...
Sir, The system checked the COD files in the device for modification and determined that a problem exists with one or more COD files.If all loads fail, a build process error might occur (a problem exists with signing the COD files).If a user action on the device resulted in this problem, the reset cycle is continuous because the code in the filesystem has been corrupted. The only recovery method is to wipe the device and restore a new system.
Jul 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
I dropped my blackberry and a jvm errror 103 error shows up
Contact your cell phone provider. They may have a solution for the error code. If restoring doesn't work, chances are it is a hardware failure
Apr 08, 2009 | RIM BlackBerry Curve 8310 Smartphone
Net
hello there!
By using your phone as a modem, you can get Internet access via your PC. Before you can use your phone as a modem, your service provider must enable your data line. Once the data line is enabled, you must set up your PC.
You can connect your phone to your laptop via USB cable or bluetooth. then open the PC suite for sure there will be set up for this.
You will need the PC suite to do this.
Set up the Data account in the Sony Ericsson K750i:
  • Go to Menu
  • Select Connectivity > press Yes
  • Select Data Communication > press Yes
  • Select Data Accounts > press Yes
  • Select Add Account > press Yes
  • Select GPRS Data > press Yes
  • Enter Name as :mnet
    • APN : mnet
    • Give User name as: mnet
    • Give Password as: mnet
  • Select Save > press Yes
  • Connect your Sony Ericsson K750i with cable.
  • If you are using the USB cable or DSS-20, then
    • Double click Phone Connection link
    • Uncheck the USB prot.
  • Click Start > Programs
  • Select Sony Ericsson > Mobile networking wizard
  • Select Create new connection > GPRS
  • Select Install Modem > Add (install the modem on the same port of the USB)
  • Select Access point name as :
  • For Primary and Secondary DNS: leave blank
    • Give Password as:
  • To confirm select Done
  • Select Connect > Dial
With the Sony Ericsson PC Suite software installed on your PC, you'll be able to synchronise your phone contacts, calendar appointments, tasks, notes, emails and bookmarks between your phone and your PC at any time. You can synchronise using USB cable, Bluetooth™ or Infrared (IR), depending on phone model.
To be able to use Sony Ericsson PC Suite with your PC, there are some requirements on hard disk space and Windows version that must be met. Please see Software downloads on this site to download and for details on the requirements for your phone.
Oct 20, 2008 | Computers & Internet
22 people viewed this question
k24674
jasbo
jasbo
