Where is filter on duraflame heater to clean - Heating & Cooling
Shut off cleaned filter won't turn on may will after a day or so any suggestions?
Most thermostats and condensing units have delays up to 5 minutes if you shut a system down and then RN it back on. Is the blower running if you switch fan to on? Where did you shut it down at? The thermostat or breaker?
Apr 10, 2016 | Duraflame Colby Indoor Infrared Quartz...
Turns on for 1 minute and gets Er - I cleaned filter
It may be getting too hot and activating the safety shut off. This may need a new board. I have never worked on one of these but it has to be fixable. Depending on the cost of the unit as to whether or not it is worth it.
Mar 04, 2016 | Duraflame Powerheat 1500W Infrared Quartz...
My flame quit working in my red core heater. - Redcore S2 IR Stove Heater - Space Heaters, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
Jan 10, 2016 | Heating & Cooling
How do I buy a filter for my duraflame #10HM4126POA?
It's no longer being sold. If your owners manual has no contact info for parts, just Google your brand and model. If that fails, measure your filter dimensions and buy a generic filter sheet at a hardware store. I have a similar model and I don't see why a 3M fiber pad wouldn't work. Just remove it periodically, wash it out, dry it, and reinsert.
Dec 26, 2014 | Heating & Cooling
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Heating & Cooling Logo
232 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
