Question about Samsung Dishwashers
Samsung dishwasher has a blue light on the front panel that won't turn off. Why?
3 Suggested Answers
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
gopakumarg43
  • 74473 Answers
SOURCE: Samsung PS-42S5S plasma TV won't turn on. Blue power light on front panel flashing slowly. Instructions say TV using power management. Used remote, power button on front of TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Mar 25, 2016
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Samsung dishwasher fills and drains repeatedly
I would check the drain itself. Make sure there aren't any eating utensils getting caught in the drain area.
Jun 01, 2015 | Samsung Dishwashers
Coffee pot located on counter directly above dishwasher leaked coffee down front of dishwasher. Heavy light began flashing and will not stop. What can I do?
Actually, I think some coffee got down into the base and triggered the flood sensor. (Or it may coincedentally be that your dishwasher has a leak that triggered the flood sensor). You would have to pull the DW out, remove the panel on the left and right-hand sides, and dry all the water (or coffee) out.
Feb 19, 2015 | Samsung 24 " Built-In Top Control...
I start the dishwasher and it does nothing and lights do not turn on either
When your dishwasher won't start, it could be a problem with your electrical panel or the door might not be closing properly.
Check your household electrical panel for a tripped breaker or blown fuse. Also check to make sure the door latches closed properly.
For additional troubleshooting steps you can take and things you can do, read Dishwasher won't start for more suggestions. I hope this helps!
Aug 02, 2012 | Kenmore Dishwashers
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Jun 23, 2011 | Samsung Dishwashers
Samsung 50'' Plasma Power Problem
most likely you have a bad power supply look for bubbled caps on the power supply if you don't see any then I would replace the power supply. if you do then I would just replace the caps and that should take care of your problem
Jan 28, 2010 | Televison & Video
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
