I have planar pl 1700 led which is in auto adjustment progress and image is blinking No button working How can I reset this problem
Benimur
  • 6966 Answers
SOURCE: Blinking
Hi, You may want to try lowering down the screen resolution of your display properties of your PC. If you can't set it properly or the monitor will not allow you to do so, try restarting in safe mode (press F8 when booting). Pls post again how things work up so we will know if this did the trick or we have to come up with something else. Good luck and kind regards.
Posted on Aug 06, 2007
jemmyrash
  • 180 Answers
SOURCE: auto adjust in progress
if you tell me that you've reinstall the vid card software .
it might have be your video board in your LCD that have trouble you.Up to certain of time of your usage the component get heatup it get shorted. Try to get video board replaced.
Posted on Apr 18, 2008
viziks
  • 220 Answers
SOURCE: Blinking auto adjust in progress
The problem is with front panel switches which needs to be replaced.
Samir
Posted on Sep 12, 2008
  • 285 Answers
SOURCE: auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Posted on Jun 09, 2009
SOURCE: Auto Adjust in Progress
Disconnect the monitors plug. Unplug the power cord. You may not have to do both, but it reset mine and it works fine now.
Posted on Apr 29, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
What type of adapter will I need to connect my pl 1700 monitor into my mac mini?
you'll need one of these
http://store.apple.com/uk/product/M9320G/A
mac mini dvi to vga adapter
Apr 05, 2011 | Planar PL1700 17" Flat Panel LCD Monitor
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Pl. solve my problem "PROCESSING AUTO IMAGE ADJUSTMENT" message display continusly
I've tried all ideas by removing this ,,processing auto image adjustment'", but all of them was not working. So, i found truly and simple solution: The problem is made of constant autoself incorrect working button ,,Auto/set". This button is near ,Turn off/on monitor". Eventually you need to turn off this button, but there is no solution to do it, but i found one - i used hair clipper to press this button PERMANENTLY. And it WORKED, and also no screen buttons are working
Oct 02, 2010 | LG Flatron L1515S 15" LCD Monitor
I have a Planar 1910(Black) LCD from a friend. It first had a problem where it would show no display but the power LED would flash green to orange. I fixed the problem by reseting it. Now that the display...
It has white screen becuase it may not be getting the 5vdc from the logic board to the T-CON board or the board has blown fuse.
Please see http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Also look to see if power supply/logic bd had any bad caps also.
Aug 14, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Monitor setting panel on permenantly
mrjk65, If monitor still has bright, crisp images displayed on the LCD panel your monitor could be worth saving! Unplug unit from wall outlet and plug it back in! If same problem occurs then most likely problem could be a DC voltage is slightly "out of spec" or a settings panel push switch may have failed. My guess is that when STRANGE out of the BLUE things start to happen for no reason, I would suspect the "switch-mode-power-supply" to be the item at FAULT. Visit YOUTUBE for vids of "LCD monitor disassembly" , "LCD monitor repair" . You will be glad you did. Also try www.ccl-la.com/badcaps.htm , www.lcdparts.net , www.badcaps.net for more info. hope this helps. Bye for now. 12fixlouie.
Nov 08, 2009 | Planar PL1700 17" Flat Panel LCD Monitor
Samir
Aug 27, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Cant take printouts
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
k24674
