Whacauses the house clog up and how can i get it unclogged
    Top Expert:
  • Office Equip... Master
  • 49,276 Answers
Call a plumber
Posted on Jan 01, 2017
Whirlpool duet sport is clogged. Water is bypassing the detergent dispenser, and leaking out of the washer. No water is entering the washer. HOw can it be unclogged?
If you take the drawer out you may be able to gain access to where the clog is, if not remove the lid of the machine and you will see the fill hose from the drawer to the tub. You may be able to remove the pipe without removing the dispenser housing or you may be able to get to the blockage by removing the pipe from the drum.
Dec 28, 2012 | Whirlpool Washing Machines
Can't unclog stubborn bathtub drain
find a local hardware store or depot with a plumbing department and get a drain auger, it is a long wire with a spring around it that ends in a few hooks you can use to manually remove the clog if chemical clog removers do not work.
Aug 21, 2011 | Home
Fabric dispenser is clogged. How do I unclog so
The dispenser is removable easily. You can scrub down the softener dispenser and it will eventually work.
Jun 12, 2010 | GE WSXH208A Front Load Washer
I have kenmore progressive and it is clogs is there a way to unclog it
The easiest way we unclog this machine is to take another canister vacuum and use its' hose to put on the hose of your machine then switch it on and **** the clog out of your machine. Works great.
Dec 01, 2009 | Kenmore Vacuums
The spin cycle will not work. I think the drain is clogged and would like to figure out how to unclog the drain
If you unscrew the bottom front kick plate there is a black rubber piece to the right in front. In order to get to the filter make sure the washer has no water in it or it will spill all over the floor. The black rubber piece houses the filter. You need a phillips screwdriver to unscrew the clamp at the top of the black rubber piece. Once that is unscrewed you can pull it down and you'll see a white plastic filter inside. It is most likely clogged so it won't drain. When it is cleared it will work again. It is pretty easy but can be messy if there is water still in the drum. Just make sure that you put the rubber gasket back on with the clamp tightened.
May 02, 2009 | General Electric WSSH300G Front Load...
The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing.  Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees.  Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do...  If it does help, please rate me!
Nov 27, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
24 people viewed this question
