Question about Delta Saws
I need a blade guard assembly complete for my delta table saw model 34-802
    Top Expert:
  • Delta Master
  • 49,193 Answers
Only delta can help you with this one
Posted on Jan 01, 2017
Not sure about the Delta. I've had both a Craftsman and a Dewalt. On both of those, the pivoting plastic guard pivots on a plate on the side of the metal guard. The plate isnt easy to see. You rotate the plastic guard all the way open and you see the edge of the plate held in place by a screw. Remove the screw and the plastic guard and the hub along with the plate it's mounted on can lift up an half inch or so--far enough to get the blade screw off the arbor.
There's a push button somewhere that locks the blade from turning so you can turn the screw in the center of the arbor with a wrench.
Sep 16, 2014 | Saws
Need a lower guard for delta model 36-220 10 inch miter saw pn 1343989
That part is no longer available from Delta or any parts supplier
Sep 22, 2012 | Saws
How can i get a guard for this table saw the dw 746
You can order them at
The DW746 and DW744 use the same guard assembly, if you're talking about the hinged guard over the blade.
Mar 29, 2010 | Dewalt DW746 10" Woodworker's Table Saw
Delta saw model no. 28-245 saws a taper form top of wood to bottom why does it not saw a stander line Delta saw model no. 28-245 s/n 91B1335
Sounds like your table is tilted. Put a small square on the table against the blade, then adj the table to it. If that is not it, then the blade guides are off up and down, back off all the guides, wheels, turn the blade by hand, get it tracking in the center of the tire, then bring the bearings up the blade, don't push it , just touch it, then bring in the guides, again, make sure it doesn't push it, the guides stop it from going off, it should track by itself. Hope this helps.
Feb 05, 2010 | Delta Saws
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Missing parts for guard assembly craftsman table saw 133.299315
You will have to start searching craigslist and amazon, estate sales, garage sales etc.
Nov 24, 2008 | Craftsman Saws
Saws Logo
48 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
