Washing macchine will not go through the cycles it will fillup and start to wash then stops and wont move on to the next step
  • 784 Answers
Your motor is good that why you had agitation.
If you try to set to run by spinning only and it's still not working then the problem is not at your timer, but it is at the spinning mechanism.
Your motor is designed to turn both directions. One is for agitation, the other is for spinning. In order to spin, the mechanism has to work properly to engage with the tube to turn. The mechanism involves the clutch, the brake and the pulley. One of these fails to function as designed, the tube is not spin. In order to find what exactly wrong, the front panel needs to be opened to inspect. Now you can not manually turn the tube from inside since the brakes are engaged by default. If you are handy, inspect it to see if you can tackle the diagnose to change the parts. Let me know if you need help.
Posted on Jul 21, 2009
My machine wont stop pumping water into it
check for a blocked hose to the pressure switch or a faulty pressure switch
this switch is controlled by water increasing the trapped air pressure on a diaphragm and when the setting on the wash size is reached , it closes of the inlet water solenoid and turns the machine to the next cycle.
if it does move to the next cycle then the solenoid stops on the water hoses are faulty and need to be replaced.
May 19, 2015 | Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Washing machine keeps stopping at the beginning of a cycle
If you leave it on its own, how long/will it ever, advance on its own?
Nov 05, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
