Question about Kitchen Ranges
I push the self clean button on the oven it never locked but now won't let me use the oven
I was Having problems with the profile control panel won't let me heat oven past 350
Powerman
  • 68 Answers
SOURCE: GE Profile Spectra Electric Oven Self clean malfunction and F7 error
I can't help with the burn marks, but have considerable experience with the F7 problem. Click on the following link for my solution:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success. Please let me know if this works for you.
You can email me at hutchipop@yahoo.com
Posted on Nov 22, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Posted on Mar 09, 2010
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
    Kelly
    Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
    Whirlpool Accubake self cleaning oven problems
    My Whirlpool Accubake oven just did the same thing. There may be a class action suit... contact Emge
    Jun 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Electric Self cleaning oven locked still lit
    There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch may solve the problem.
    To reset it:
    TURN OFF THE POWER!
    Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
    remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
    pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
    Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. usually located nearly in the middle of the electrical enclosure.
    Push the tiny button on top of the switch. You should feel a click.after Reassemble and power up.
    hope this solves the problem do let let me know i will appreciate a fixyaa rating thanks and Godbless
    Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven door will not unlock after self cleaning
    I had the same problem, and after about a month of troubleshooting, I finally found the problem. There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
    To reset it:
    TURN OFF THE POWER!
    Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
    Push the tiny button on top of the switch. You should fee a click.
    Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    JTP56 Self Cleaning issue
    It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
    Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
    Thanks, Mike
    May 06, 2008 | GE Profile JTP56 Electric Double Oven
    Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
    most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
    you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
    Print Range - “LOCKED DOOR” flashes in the display
    If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
    Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
    Kitchen Ranges Logo
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
