Question about Coffee Makers & Espresso Machines
Impress z6 model when making cappuccino, the coffee frequently comes from the wrong spout. It comes out of the regular coffee dispensing spout and not the cappuccino spout
SOURCE: milk is not dispensing hot enough from saeco
If you use cold milk, I don't think it has enough heating power to make it hot enough. What I find works best is using long life milk from a carton which is room temperature, or making the milk room temperature warm in the microwave first before pouring into the milk containter
Posted on May 08, 2010
  • 22306 Answers
SOURCE: Machine sat for 2 weeks (not plugged in).
could you try back flushing it ?' must be possible ,as it sounds like the coffee grouts have got stuck in the water feed to coffee spouts so try a hose in the garden and try flushing it backwards through the spouts put finger on one and hose on the other and see what happens .
Posted on Dec 03, 2010
  • 1711 Answers
SOURCE: when making cappucino coffee using
The problem
you describe it can occur if you don't perform the tablet cleaning as describe
in the user manual at page 30, (see link below).
The machine
changes the direction where the coffee will be delivered via a solenoid valve.
The coffee oils that remains inside this solenoid every time you make a coffee
they can dry out and after many coffees and if you don
Posted on Jan 09, 2011
  • 395 Answers
SOURCE: My Tschibo Caffissimo Classic will not let coffee come out of the spout, why?
Clean the port using a small paper clip. Push it up the tube and pop out the material that collected inside.
Always use Distillate or Filtered water.
Posted on Feb 02, 2015
SOURCE: My z5 is out of
It is likely the push pull solenoid at the upper right of (facing) machine.
My machine was pumping coffee for cappuccino and special cups from the wrong spout (center spout) vs left spout.
I opened up the machine and found this solenoid which is supposed to push a lever that switches the flow of coffee between center and left spouts.
In my machine the solenoid wasn't working. Three potential causes of failure: 1) solenoid is stuck (mechanical issue) 2) solenoid failed or 3) power to the solenoid failed.
In my case it was 1) solenoid was stuck. I used a needle nose pliers to grab the nub of the solenoid push shaft and pull it out. You may need a butter knife to pry it out enough for the pliers to have something to grab. I moved the shaft in and out a few times, put the machine back together and I was back in business.
That's the short version. While I had the machine open I tested resistance across the solenoid using my ohm meter, and current to the solenoid during the left rinse cycle, ruling out both electrical causes. This was fortunate because I couldn't figure out how to remove the solenoid.
Posted on Aug 13, 2016
Cannot get steam to come out of my delonghi prima donna XS coffee machine
Could not find why but maybe if you go back over the scaling procedure and steam procedure there might be something you missed.
Please note! If "Energy saving" is active, you may have to wait a few seconds before hot water and steam are delivered.
Steam delivery 1. Make sure the hot water spout is attached correctly (fig. 7). 2. Fill a container with the liquid to be heated/frothed and immerse the spout/cappuccino maker (D5) in the liquid. 3. Press the steam ( ) button. After a few seconds, the steam to heat the liquid comes out of the cappuccino maker and "STEAM" is displayed. 4. When the required temperature is obtained, interrupt steam delivery by pressing the steam ( ) button again. (You should not discharge steam for more than 3 minutes at a time).
customer support
Customer Support
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
I need to get a new spout where do I order?
You did not mention the make and model of coffee make.
There are over 1000 different coffee dispensing spouts.
Mar 02, 2015 | Coffee Makers & Espresso Machines
When I try to make a cup of coffee, only a small amount of water and coffee come out (like a shot of cappuccino) of the coffee dispenser while hot water is dispensed (simultaneously)...what could be the...
the flow pipe is blocked. you need a nylon thread to clean it out. you push it in and out a few time in the hole until it is clear. shold of come in the kit when bourght new
Sep 22, 2013 | Miele Coffee Makers & Espresso Machines
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
How to work Spidem Cappuccino Instantly Espresso Machine
the coffee portion of the knob only allows the instant coffee to be added to the mixing process, then when the knob is turned to the milk selection, the milk is frothed and the instant coffee is added and dispensed into a container under the dispenser area on the front of the machine......Hope this helps.
Aug 16, 2008 | Coffee Makers & Espresso Machines
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
