Sorry i have a fuzzy logic 8.2 washing machine and the rotating plate has come lose can you show me how i can use thread loctite on the shaft to keep it tight
3 Suggested Answers
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
  • 6277 Answers
SOURCE: my fuzzy logic top loading
Manual first- You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
Beeping Sorry I'm unsure of which manufacturer makes the 'fuzzy', I should know! 'e9' could be a filter block.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 12, 2011
HOW TO STOP EXCESSIVE SHREDDING AND BREAKING OF THREAD ON A BES-1210AC
Sorry, do not recognize the make model machine.
Be sure to use good quality thread--NO old or bargain bin threads or thread that shows "fuzzies" projecting from the thread!
Use needles that are compatible with the thread and fabric being stitched.
Check that there are no burrs or rough spots in the thread path--also check the needle plate and bobbin/hook area for rough spots that could snag the thread.
Dec 23, 2017 | Sewing Machines
My washing machine shows a F, it rinse spin s and dry but don't wash
Completely striking out looking for our machine ... or codes
little further research tells me it is DEFINATIVELY not the USA market...
Get your T1303TEFT manual here:
https://www.manualslib.com/manual/644235/Lg-Wft11g00ted.html#manual
For service in your area...
Telephone Call an LG Support Representative at
Jordan
Saturday to Thursday: 8:00 am ~ 7:00 pm
Except national holidays
080022154 (Land line)
065608530 (Mobile / Land line)
Iraq
Saturday to Thursday: 8:00 am ~ 5:00 pm
80011110
Lebanon
Monday to Saturday: 8:00 am ~ 7:00 pm
1273
Syria
0115495400
Sorry didn't SEE that coming Carnac the Magnificent
Jan 13, 2017 | LG Washing Machines
Impeller within top-loader loosens and floats
On the top of the splined shaft that holds and turns that agitator, there is usually a locking tab on the bolt or washers. Check to see if there is a hole in the shaft for a castle nut to use a cotter pin. You can also use a locking nut on it. They have a nylon part that allows the thread to cut into it and it wont back out. Last you could use LOCTITE on the threads to keep the nut from coming off.
Dec 16, 2013 | Washing Machines
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Machine rocks, all four sides, removed and oiled clutch bearings, tightened the belt, still rocks and errors out no matter the size load, machine is balanced. ?
I feel you still have a clutch problem... Did you try this test before you cleaned up and re-lubed the One-Way Roller clutches in the Clutch pulley?
From my Clutch Fix post;
Let's demystify dC and uC error codes plaguing the FAV6800A and the LCD Flavor FAV9800A
One last step before you clean up those pesky Clutch Pulley One-Way Roller Clutches/bearing.
Holding what I call the Spinner Shaft coupler first picture. Insert that coupler into the Clutch One-Way Roller bearing plate.
Now while holding the Spinner Shaft Coupler with one hand as I show in the second pic with your other hand rotate the white bearing plate in the CW direction around the Spinner Shaft Coupler.
The One-Way Roller Clutch bearing plate should rotate freely in the CW direction this is the wash/agitate direction.
Now rotate the One-Way Roller Clutch bearing plate in the CCW direction it should lock up solid.
Most times the One-Way Roller clutches will slip did it slip for you? This will cause the agitator shaft to move slightly causing slight tumbler rotation while the wash basket begins to spin up unbalancing the wash load causing big time wash tub swings and those pesky unbalance error codes.
The Control Board sees the TDS analog voltage swings out of design limit and shuts down the spin cycle. If the TDS was not working as designed the machine would walk across the room and unplug itself or self-destruct.
The Control Board programming will try several attempts to redistribute the wash load and when the magic number of wash load redistribution attempts has been reached the Control Board signals a dC or uC error code to the display. I believe the FAV9800A signals a text error to the display i.e. "unbalance condition?" or something like that.
Anyway I thought you might want a little more insight into just what is going on here. A very poor Clutch design by Maytag. Mine failed at the 3.5yr mark of service and I was not about to trash a $1K machine. Sorry to say I feel number of them do make it to the curb on bulk trash pickup day.
I call this the Spinner Shaft Coupler. Not sure what Maytag calls it.
This is the One-Way Roller Clutches/bearing.
While holding the Spinner Shaft Coupler with one hand rotate the white One-Way Roller Clutches/bearing plate in the CW Wash/Agitate direction with your other hand. It should rotate freely in the CW direction around Spinner Shaft Coupler.
Now rotate the white One-Way Roller Clutches/bearing plate in the CCW direction the Spin Cycle direction. It should lock up and not rotate CCW around the Spinner Shaft Coupler. If it does the tumblers will rotate slightly and cause the wash basket load to go off balance as the wash basket spins up.
If the TDS is working as designed the machine will fail in Spin Cycle with dC or uC error codes. If the One-Way Roller Clutches/bearing can be cleaned up and re-lubed you could be back in service with no cost.
If so what were the results?.................Rich
Oct 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine drive belt keeps coming off indesit wib111. the nut which holds the drum and the whell keeps also undoing, no matter how tight i do it up.
Try putting some locktite on the thread of the bolt. Loctite is a liquid you can buy to lock bolts into there threads.Alternativley the pulley that the belt runs on may be worn & sloppy in the centre where it goes on the metal shaft.you may need a new pulley as well as Loctite..but try the Loctite first.
May 31, 2010 | Washing Machines
Apr 07, 2010 | LG Washing Machines
Centrex top loader washing machine Model # CTW60519 6kg Auto Washer. When washing the center screw holding the base plate unscrews. The base plate lifts and the clothes are not washing clean. We have...
The part that the screw holds is turning independently of the screw. Remove it and inspect for torn splines or other motion locking device. Repair or replace the part using Loctite on the screw threads.
Sep 14, 2009 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
