Question about Lands Phones
My Blu 6.0 xl 2 when placing a call I don't hear any ringing and I Can't receive any incoming calls. It just stop working
sandrew
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
  • 201 Answers
SOURCE: We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
Posted on Aug 30, 2007
SOURCE: IPhone - Can't hear incoming calls. Does not ring or Vibrate.
I had a similar problem....it was usually after I unplugged the headphones....the phone thought they were still attached, therefore, nothing came over the speaker......try plugging in the headphones, then unplugging...that worked for me.
Posted on Jul 25, 2008
SOURCE: can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Posted on Mar 03, 2009
consultel1
  • 860 Answers
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Posted on Jan 12, 2010
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
