Question about Singer Sewing Machines
My needle will not pick up bobbin thread on my singer protege model 2639
  • Singer Master
  • 12,273 Answers
Try installing a brand new needle.
If it still will not work, most likely the machine has been knocked out of time. Take it for service.
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Jun 26, 2010 | Singer 2639
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Jun 08, 2009 | Singer 2639
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Sewing Machines Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
