Question about Xerox Workcentre 7345 Printer, Copier, Scanner
Xerox Workcenter-7345 Printer I Phash This error code 004-345 Solve This errar Plz Its Emergency
  • 2072 Answers
SOURCE: scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Posted on Dec 22, 2008
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
SOURCE: our xerox workcenter 7235 fault
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Posted on Aug 05, 2010
wrinaldo
  • 185 Answers
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit Item, Inc.
Posted on Dec 02, 2010
Xerox workcenter 7345 erore code 009-383 ?
Your is an "ATC error" indicating that the density test has failed for Black. There are many possibilities, but here are the top 5:
1) Dirty or defective ATC sensor (130K63000) (difficult to reach..recommended to be done by technician)
2) Defective Developer (802k60194) (also difficult) You also need Developer Charge Powder (604K22550)
3) Defective ATC Clutch (121K23270) (also difficult to reach)
4) Drum (013R00624) not turning, or bad drum
5) Drum motor (007K88604) not turning
xerox and tektronix dell canon konica minolta qms samsung lexmark okidata...
Feb 07, 2016 | Xerox Office Equipment & Supplies
Xerox 7345 error code009-936 has been received. Please send the solving process.
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Dec 17, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Laser printer prints streeks in magenta
swap the A2 and A3 drum.
Send a new color print
If streaks become blue, than you have to replace the drum in the A2 position.
Apr 11, 2013 | Xerox Office Equipment & Supplies
My xerox PE220 machine give LSU error. not any work in done plz give solution
plz solve my problume in my printer workcenter pe220 lsu eror and not working this time to help me plz
Dec 18, 2010 | Office Equipment & Supplies
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox Workcentre 7345 Printer, Copier, Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
