Question about Tilia FoodSaver VAC420
Need to get the bottom seal/gasket, foodsaver no longer has parts for this model. Do you know where I can get one?
  • 139 Answers
Try using a small bead of high quality,high tempature silicon caulk. put bead over existing seal and make sure it cures thoroughly before closing or you will never be able to open it
Posted on Jul 23, 2009
I have a 35-0320 foodsaver Professional II. I need sealing gaskets
Please contact Foodsaver customer service for parts, we do not sell parts here.
Feb 16, 2017 | FoodSaver Kitchen Appliances - Others
Foodsaver v485 no longer seals
Hi tami prevost
Your vacuum pump seals are wearing and not allowing the vacuum build up as it was new...
Look at the manual that came with it and see it you can order parts for your vacuum foodsaver, if you can order the seals/orings,etc that is needed to repair the vacuum part of the machine.
Please take time to rate me
Bud
Oct 10, 2012 | Tilia Kitchen Appliances - Others
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
I have an older model Foodsaver. The machine will
This is likely happening because the unit cannot detect that a vacuum has formed, and the gaskets around the vacuum channel are the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Jul 24, 2010 | Tilia FoodSaver V2240
I have a foodsaver and it sucks the air out but won't seal. What do I do? We're trying to save some frozen fish and it just sucks and sucks but doesn't stop or seal. Any ideas?
The bag is wrinkled or the gaskets are leaky, it has to pull down to a set vacuum in order to shut off and heat the strip to seal the bag. For the right now dilemma try pressing down on the lid while it's vacuuming and start looking for gaskets at foodsaver.com
May 29, 2010 | Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
My tilia foodsaver is not creating a vacuum consistantly anymore, do you need to replace gaskets?
take a rag and wet it with water then run it over the seal on top and bottom. Some light cooking oil will work too.
Jun 23, 2009 | Tilia FoodSaver V2240
Foodsaver V2440 won't vacuum air out
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers foodsaver-v2440-vacuum-air-out-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Jan 07, 2009 | Tilia FoodSaver V2240
Tilia FoodSaver VAC420 Logo
1,024 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
