Question about Refrigerators
Will sea monkeys ljve on the other side of the room to the light
Where is the automatically dispenser light located on the refrigerator
Go to page 5 of your user manual HERE
Style 1: The dispenser light can be turned on by pressing the ON
Style 2: When you use the dispenser, the lever will automatically
turn the light on. If you want the light to be on continuously, you
may choose either ON or NIGHT LIGHT.
ON: Press the LIGHT button to turn the dispenser light on.
NIGHT LIGHT: Press the LIGHT button a second time to select
the Night Light. The dispenser light will automatically adjust to
become brighter as the room brightens, dimmer as the room
OFF: Press the LIGHT button a third time to turn the dispenser
light off.
The dispenser lights are LEDs which should not need to be
changed. If it appears that your dispenser lights are not working,
check to be sure that the light sensor is not blocked (in Night Light
mode). See "Troubleshooting" for more information.
I am here if you need help, Sea Breeze
Parts Manual
Mar 03, 2013 | Whirlpool GC5SHEXNS Side by Side...
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
Outside a steamroom we have a temperature control panel which displays temperature and set point. It goes into alarm if room overtemps and cuts off power to heating elements untill reset by a micro switch....
If you can isolate the room around refrigerator I can help. Room around refrigerator must be normal household temperatures. Separate power to refrigerators 20 amp. breaker and away from heated area. Thanks, Sea Breeze
Jan 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
I am on forest temple level andhave to get that gale boomerang and i know you have to defeat an boss to get it, but which room is the boss in?
You don't have to defeat the boss to get it, you need to defeat the baboon monkey creature. You'll need to save some monkeys from their cages and head to the biggest room with all the doors and go to where the baboon took down the bridge. Now you can cross the gap using the monkeys and get to the room where you can fight him for the Gale Boomerang. He's in the room labeled #10 on the map.
Oct 28, 2010 | Nintendo WII The Legend of Zelda Twilight...
Lost my 4 released monkeys!
I have a similar problem, I saved and now cannot get to the other side of the bridge, can anyone help please??
Mar 24, 2010 | Nintendo The Legend of Zelda®: Twilight...
I added grease monkey & f/b wont show log in page now
facebook does monitor everything in their games.wait for a month.see if you can now open you account.and try removing grease monkey
Mar 02, 2010 | Computers & Internet
I cant get out of the 1 dungeon
If you have obtained the Gale Boomerang go to the room inback of the temple entrance and knock down the hanging chest. It has the compass that will show the location of treasure chests and the monkey.
Apr 06, 2009 | Nintendo The Legend of Zelda®: Twilight...
Wii got find for monkeys which are the kid fund all but one
There are a lot of monkeys! If you look at your dungeon map, there should be a symbol indicating where the monkeys are, I think it is a little red cage but I don't quite remember. You might need the compass for it to show, so make sure you open all the chests and check all the rooms.
Apr 05, 2009 | Nintendo The Legend of Zelda®: Twilight...
Shrimp Instructions?
Hi brine shrimp are sea monkeys just google see monkey hatching instructions they will be the same. my instructions do not have the information either but my set came with the brine shrimp. you just wont have pouch #1
Good luck we had 4 generations of sea monkeys. When they fie off you can let the water evaporate from your tank and Add new water and the cycle wiil start all over. we are in that process now 4th time...
Dec 31, 2008 | Vivitar 900x 28-piece Microscope Set
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
