Question about Toshiba Audio Players & Recorders
Subwoofer is not connecting with sound base its a toshiba ABX 3250
I have a 50 inch Toshiba 50L4300U that has no picture but has sound. What board do I replace?
Do this test first. With the TV on normally, shine a flashlight on the screen. look for a dim moving picture.
1) If you see one, the backlight led driver isn't working.
2) If you DON'T see a picture replace the T-Con board.
You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 21, 2016 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
Can i add Cyber Acoustics 2.1 3-Piece Computer Speaker System with Subwoofer to my tv using roku3?
You can't use 2 different speaker systems connected to one device output.
You could connect the CA speakers connected to your Roku and improve your TV sound. You could also use your microlab speakers connected to your computer to augment your computer based audio.
Apr 08, 2014 | Audio Players & Recorders
Power surge on my Toshiba 50L4300U and now no sound. I do have picture
Check fuses and breakers on Polk.
If they are ok then take it to the shop.
Mar 30, 2014 | Toshiba 50L4300U 50" 1080p LED-LCD TV -...
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
I have a problem with my M&K v-2B subwoofer 120 vac 50-60 Hz, not getting good qaulity audio vocals, its real faint and when I hook up the speakers in the back the speakers aren't doing anything, not a...
Well, the subwoofer is not supposed to reproduce audio in the vocal range. It reproduces Bass frequencies. Check your set-up and connections to your satellite speakers. Based on what you have stated, this is all I can offer. Hope this helps.
Apr 06, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Subwoofer
no the subwoofer resinates the low base frequency sound, but it should be loud enough to be annoying if its turned up, check your connections, , you should also be able to feel the vibration from the woofer.......if connections are ok, it may be defective
Jul 22, 2009 | Boston Acoustics BA745 Computer Speakers
59 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Level 1 Expert
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
