Question about Refrigerators
Would sea monkeyson the other side off the room to the light
Sea-hawks burning our flag in the locker room .Is this true?
The "photograph," which has made its way across Facebook and Twitter, shows Seattle Seahawks defensive end Michael Bennett enthusiastically burning the flag in a locker room as his teammates and head coach Pete Carroll happily look on. The picture is photoshopped.
Nov 11, 2017 | The Video Game Consoles & Games
Where is the automatically dispenser light located on the refrigerator
Go to page 5 of your user manual HERE
Style 1: The dispenser light can be turned on by pressing the ON
button.
Style 2: When you use the dispenser, the lever will automatically
turn the light on. If you want the light to be on continuously, you
may choose either ON or NIGHT LIGHT.
ON: Press the LIGHT button to turn the dispenser light on.
NIGHT LIGHT: Press the LIGHT button a second time to select
the Night Light. The dispenser light will automatically adjust to
become brighter as the room brightens, dimmer as the room
darkens.
OFF: Press the LIGHT button a third time to turn the dispenser
light off.
The dispenser lights are LEDs which should not need to be
changed. If it appears that your dispenser lights are not working,
check to be sure that the light sensor is not blocked (in Night Light
mode). See "Troubleshooting" for more information.
I am here if you need help, Sea Breeze
Parts Manual
Mar 03, 2013 | Whirlpool GC5SHEXNS Side by Side...
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
My Kenmore side by side is hot around the door frame. How can I reset or rebot it, if possible. Model #10657943700
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. In this case rebooting may not change much but unplugging for 10 minutes and then replugging the power is the same as rebooting. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range. If helpful please rate this solution, Thanks Sea Breeze
Jun 14, 2011 | Kenmore Refrigerators
Outside a steamroom we have a temperature control panel which displays temperature and set point. It goes into alarm if room overtemps and cuts off power to heating elements untill reset by a micro switch....
If you can isolate the room around refrigerator I can help. Room around refrigerator must be normal household temperatures. Separate power to refrigerators 20 amp. breaker and away from heated area. Thanks, Sea Breeze
Jan 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Change filter light stays on
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Thanks, Sea Breeze
Feb 21, 2010 | Samsung RS2630WW Side by Side Refrigerator
Fitted new water filter red light will not go out
See if this is helpful here=> Reset Water Filter Light in Samsung Refrigerators If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
Dec 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
My fridge is not cold it is 2 years old it a GE
We can fix that if you want! Things like this happen even with ones just purchased. I will help you find the problem and get you going, Just say so, Thanks, Sea Breeze
Nov 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
