How can I change the auxiliary port on my Blu-ray player myself
  • 35 Answers
SOURCE: Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
Posted on Dec 04, 2008
  • 12 Answers
SOURCE: LG super blu player won't play blu ray disc
Have you updated the firmware on it? I had a similar problem with a Sony blu-ray player and I had to download an update and burn it on to a CD then allow the CD to update the blu-ray player. What's the model number of your player, I may be able to get a link to the update for you.
Posted on Feb 15, 2009
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Posted on Apr 24, 2010
  • 736 Answers
SOURCE: my blu ray player won't play blu ray copy of avatar
Try completing the update.
The update file can be found here
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
Posted on May 11, 2010
How do you program an auxiliary channel for an analog sanyo TV... DVD and vhs?
Hi have a look at the remote if it has an AV BUTTON OR TV/AV BUTTON. THE AV IS YOURE AUXILIARY channel .cheers
Mar 08, 2016 | Sanyo Televison & Video
Can I connect my Blu-ray player to a tv that does not have an hdmi plug outlet?
Yes, IF your blu-ray player has another form of out-put like RCA jacks that match what your TV does have. Use this format. By not being able to use the HDMI port from your blu-ray player will only hinder video quality. Your tv that doesn't have a HDMI port already tells me video quality wont justify what your Blu-ray is capable of. Hope this helps.
Jan 11, 2015 | LG Televison & Video
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: and Click on Support on either site.
Nov 13, 2010 | Televison & Video
I have purchased the blu ray dvd player do i need to by a coaxial jack as well as the hdmi jack
No,a HDMI cable alone will do the job.Just plug the HDMI cable one side connected to the HDMI port hub belong to the tv HDMI hub,the other side of the HDMI cable connected to the HDMI port hub belong to the Blu ray dvd player HDMI port hub.That should play ur Blu ray dvd player.U still have questions,read ur owner manual.
Jun 24, 2010 | Televison & Video
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
