Question about Olympus FE-320 Digital Camera
After pressing POWER button, the camera lens extracts and then goes back and forth two times and makes an electronic buzz sound followed by electronic ticking sound. Then shuts off.
  • vello_leitha Jul 21, 2009
    I have tried with new battery. I am thinking that the "buzz" sound is the motor and the "tick-tick" are misaligned or broken gear sounds.
  • vello_leitha Jul 22, 2009
    Sniper:
  • 92 Answers
Replace your cam. battries. I think if will solve your problem.
Posted on Jul 21, 2009
When i press power button it makes sound toot toot toot.and goes lens back.the lens opens little.what can i do to solve it?
Lens guide pin damaged or jamed. Try this if no luck visit service center.
follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 24, 2011 | Samsung S760 Digital Camera
Have sony vpc-s120 cam that states system error... lens goes back and forth and then buzzes. the cam shuts off after...
Hello
Unfortunately a "system error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Sep 21, 2010 | Sanyo VPC-Z380 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Olympus FE 230 Problem
I had the same problem. I hit it a long time ago when it did it for the first time. It has been a year since then and it is doing it again. I tried the book solution again and it will not work. I tried holding the lens, no luck, and I tried applying pressure when the lens went back in, again, no luck. Honestly, I don't think I will buy another Olympus fe series camera again. The solutions provided do help the first few times your camera does it, but you might want to start checking the market for a new camera.
Jun 04, 2009 | Olympus FE-230 Digital Camera
Power keeps shutting down.
It sounds like you may have a bad lens assembly, but you did not mention if it seems to be fully extending or not. If it is sticking, it will usually buzz. If it fails to open all the way, it will turn itself back off. This sounds like what may be happening. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Oct 05, 2008 | Pentax Optio A10 Digital Camera
Lens error,restart camera
My Camera: Canon PowerShot SD770 IS Digital Camera
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god.
Aug 31, 2008 | Canon PowerShot SD600 Digital Camera
Buzzing sound, wont come on!
Don't try and manually push in the lens at first...the buzzing is a warning letting you know that something is wrong with the camera. By accidently removing the batteries during shut down you interupted the shut down sequence. Try and turn on the camera and immediately press the play button on the back. This should reset the camera. If not and if you are under warranty it needs to be serviced. If you are not under warranty then you can try and push the lens down. Don't use a lot of force but try and gently do it.
Jun 09, 2008 | Cameras
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
I get a buzzing sound
Hello Rrosario35, This problem is related to the lens assembly. The camera will check if these work properly when it's being powered on. If something goes rong here it will turn off or display you some error messages. This problem occures when some of the lens mechanisms get out of place and jamms or damages other components. As the lens assembly is a very delicate mechanism I would suggest you to go back to the service center that fixed it the first time and ask them to check it. Don't try to power the camera on anymore because the lens assembly could be damaged further or beyound repair if the servo-motors are trying to alling the lens something jamms them and not allowing them to move properly. This will force the servo-motors and they could damage other components or themselves. It could be fixed, but don't force the camera to work anymore for the time being. Please post back if more informations are required.
Mar 22, 2007 | Kodak EasyShare V570 Digital Camera
Olympus FE-320 Digital Camera Logo
186 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
