Question about Miscellaneous
Can I take eating nuts on plane to spain - Miscellaneous
Are Nuts Healthy?
Nuts are the ultimate health food. High in protein, rich in healthy fats, and low in simple carbohydrates, nuts stimulate your body to burn excess fat and shed extra pounds. Plus, they make an incredibly versatile addition to your diet. When eating nuts for weight loss, remember to keep calories in mind.
Jan 04, 2018 | Health & Beauty
I am having a colonoscopy on Sat morning been given a list of what to avoid but not to eat I am type 2diabetic also a heart condition ie chronic heart disease
dont eat nuts or anything high in fiber. also nothing to drink thats red all 24 hours before your procedure. oh and dont worry its fairly quick and for sure painless..good luck
Jun 21, 2017 | Health & Beauty
Snopes fact or fiction
No, dogs should not eat any nuts, ir grapes orvraisins or tomatoes or onions.Lits of human food is lethal to dogs and cats.
Jan 26, 2014 | Dogs
Are there nuts in honey nut cheerios?
Strangely enough, there are no nuts in Honey Nut Cheerios. Although the box does warn that there can be trace amounts in case someone that is allergic to nuts wants to eat it.
Jan 10, 2013 | Cooking
I just received a new Handyman No4 but I dont know to where to set the adjusting nut! Does the "horse shoe" fit inside the plastic in the nut or in front of it? The instructions provided are not...
I'm not sure exactly what you're referring to as a "horse shoe". However, you will find a wealth of information on exactly how to set up and tune your hand plane if you search google for "tuning a hand plane" There are videos and books that deal with the subject exhaustively. Here's a link to one.
In general, I have only used a variety of wooden and cast iron planes, and so I'm not familiar with a plastic adjusting mechanism. I hope these instructions will help you nevertheless...
Here's a complete set of instructions for the No. 4 smoothing plane, that includes a list of the terminology used to describe the plane's parts. If you can, please read that and provide a more detailed description of your problem. The cap iron needs to fit tightly against the plane iron (or blade), with the iron protruding just about 1/32 or 1/16 of an inch beyond the cap iron. Then these fit down over the adjusting lever or cam depending on the plane, and the lever cap adjustment screw should be adjusted so the lever cap snaps into place with some force, but still allows the iron to be adjusted slightly in and out with the adjustment screw. The main adjustment screw is usually beloew the iron at the rear of the frog, that wedge shaped piece of steel that supports the iron.(Some people release the lever cap tension before adjusting the iron, but with correct screw tension this should not be necessary.) I hope that helps and doesn't sound like jibberish.
Otherwise, you may find better instructions with a detailed search here,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 01, 2011 | Stanley 12 - 905 Contractor Grade No.5...
Can't loosen the blade of a Ryobi Electric Plane. One of the nuts is rounded. Any suggestions?
There are a couple things I do in a situation like this. 1. Does this nut tighten / loosen in a reverse direction? Some nuts are reverse pitch on the thread. They turn in the opposite direction so that the machine always maintains a direction where the nut stays tight. Try using a vice grip pliers to remove the nut. Try both directions. 2. Do you have enough space to cut the nut off? A dremel tool with a cutting disk could be used to cut through the nut without damaging the shaft. Make sure that the PLANE is NOT plugged in!
Jan 28, 2011 | Ryobi Garden
1998 megane 1600 auto box
if you have a donor car then yes you can fit a manual box,no difficulty with a auto box here in spain but its logistics cant exactly take it on plane with you
Oct 17, 2008 | 2000 Renault 181
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
