Is there a summer and winter setting for the daytek air conditioner. If yes, where is it?
  • 659 Answers
SOURCE: My Lennox Air conditioner only heats
It is possible that it's the thermostat. When you turn it into cool mode, does the unit come on at all or is it silent? If nothing is coming on, then it's likely it's the tstat. Did the tech check the refrigerant charge while he was there? He should have checked it with the auxillary heat off and the unit just in heat mode. Make sure that the condenser unit outside is coming on when you are calling for cool, If you turn it on and everything comes on, go outside and put your hand on the large copper pipe coming into the unit. In cool mode, this pipe will be cold to the touch and in heat mode, the pipe will be warm to the touch. There isn't much you can do on your own with the exception of changing the tstat. If you can answer some of the questions I have posed, I can try and give you some more answers. Just remember that a check up doesn't mean its a guarantee that something won't happen the next day, it's just that everything was in working order at the time of the checkup.
Posted on Mar 21, 2009
cadman000
  • 607 Answers
SOURCE: 1990 Cadillac Eldorado coupe
Sounds like you mean the " blower " is still operating with the ign key off. Probably a faulty BLOWER MODULE located under the R/R hood. It is a unit mounted on the A/C evaporator case against the firewall. Has 2 electrical connectors and 4 small mounting bolts. In order to confirm it being faulty, FIRST LOCATE MODULE, you note it malfunctioning, tap it, and if the blower turns off, BINGO. Hope this helps
Posted on May 14, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have problem with LG S186GH Air Conditioner
Hi, I looked up you're unit to see just what I already assumed it was, a split system, ductless,9kb.t.u. Ok, 1st go to the outdoor unit to see if it comes on when you turn your t-stat to heating, and be sure you lower the temp. enough to do this test. There maybe a time delay before it starts up, but not long,1-1/2 min. If it doesn't start up, we know that there is a problem.If not on, make sure you check for the power source, locate the breaker it may have tripped, or right at the unit there is a elect. box that should contain 2-fuses.They may be hidden from site under a shield you may have to remove. Check all of this only if this unit is not running. Reset breaker, or replace fuses if not running.If that was the problem and it was off, and now its on, you will have to watch it and if it continues to loose power, you have a problem in a componant as the compressor, condenser fan motor, open or shorted run cap, contactor Ect.You could have developed a freon leak, and it could be off on low pressure.If it is running, it still could be low on freon, reversing valve not changing over, many things can cause this Im afraid to say.The main thing to do or to start, would be to make sure that the outdoor unit is on, fan on, and compressor running if you listen at where the wiring and copper lines enter.You may need to call a tech if you check these things i have suggested and you have no luck. Please be safe and let me know, and we can go from there before you call anyone out.
Sincerely,
Shastalaker7
Posted on Nov 17, 2009
  • 40 Answers
SOURCE: Air conditioner on 1993 Pontiac Bonneville was
check freon in the system
Posted on May 12, 2010
  • 14 Answers
SOURCE: my air conditioner is blowing air but not cold
Needs the air con gas replaced
Posted on Jun 18, 2010
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
Tip
All Air conditioners
Hello
To keep your air conditioner running smoothly you should consider having it serviced twice a year be for winter and after winter. in summer have a look at cleaning your filters regularly to keep them dust free.
Thanks
on Jun 17, 2011 | Heating & Cooling
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
Mar 01, 2014 | Amcor PCMB-12000E Portable Air Conditioner
I can't find the summer switch on my furnace model FG6RA 072C-12A
there isn't a summer switch - the thermostat will switch the operation from heat/winter operation to cool/summer operation. I.E. "Cool" for Summer and "Heat" for Winter.
Aug 05, 2011 | Heating & Cooling
I need to lower the thermostat down to about 50 degrees farenheit, for the summer but want to keep it that way through the winter also so i want the heater to work also
if you set the thermostat down that low, for a space that it can not condition that low - the unit will run until it freezes up and possible damage the compressor.
Mar 05, 2011 | Danby DPAC8399 Air Conditioner
We have just had a Honeywell H46C humidity controller installed. The technician told us to set both the humidistat and digital thermostat at 65 degrees when we leave the FL condo for the summer. Is this...
If you are leaving for SUMMER, definitely do not need to set at 65, that would be tremendous waste of energy. Humidistat in summer should be off. I wonder if he thought you would be gone during winter.
Feb 04, 2011 | Honeywell Heating & Cooling
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Edgestar Portable AC/Heater
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Dec 02, 2007 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
