Question about Cameras
Have traced the lock switch ,have switched power off and on but had a no go Also when I found the switch it was already in the open position??
  • Cameras Master
  • 5,412 Answers
Please let us know which make and model of camera you are having problems with. Without that fairly basic information, we can do little to help, I'm afraid.
Posted on Jan 01, 2017
I can't find the fuse for the power windows on a 1998 Lincoln Navigator
All the other windows work ? Not a fuse , one fuse powers all the windows . Test for B+ voltage at the switch an the window regulator would be the proper diagnostic procedure . Do you own a volt meter ? know how to read a wiring diagram ? how to do basic automotive electrical testing . The Faint click you hear is probably a relay , which means the GEM - genaric electronic modual is energizing the window relay . The windows are computer controlled .
The GEM will activate the OTD Relay until one of the following conditions is met:
  • The LF regulator control switch is pushed to the UP position.
  • The LF regulator control switch is released (OFF position) and then moved to the down position (first detent) or one touch down (OTD) position (second detent).
  • Seven seconds have elapsed since the OTD was initiated.
  • A window regulator electric drive stall condition is detected on the one touch down sense line inputs.
The UP window operation is not controlled by the GEM. The feature is activated when the delayed accessory is active and the LF window regulator control switch is pressed to the UP position. The switch provides delayed accessory power to one side of the motor and ground to the other side through the one touch down relay. The one touch down relay is not active when the LF regulator control switch is in the UP position.
Passenger windows may be raised or lowered using the LF master control switches or the appropriate passenger window switch. Passenger window switches receive power when the delayed accessory relay is active and the LF remote lock-out switch is in the UNLOCK position. When in the LOCK-OUT position, the passenger windows are deactivated.
The GEM controls manual down and auto down window movement with the down window relay. The relay is activated by applying ground directly to one side of the down window relay coil, and deactivated by removing the ground signal.
The delayed accessory relay provides power for the operation of the power windows and the power moon roof. The delayed accessory feature is active when the ignition switch is in the RUN or the ACC position, or when the ignition switch is changed from RUN or ACC to the OFF/LOCK position and the LF and RF doors are closed.
The GEM will deactivate the delayed accessory feature when:
  • the LF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • the RF door is ajar and the ignition switch is in the OFF/LOCK or KEY-OUT position.
  • 10 minutes have elapsed since the ignition switch was changed from ACC or RUN to the OFF/LOCK position.
Feature inputs:
  • LF door open warning switch (open circuit with door closed, grounded with door ajar).
  • RF door open warning switch (open circuit with door closed, grounded with door ajar).
  • Ignition switch RUN position (battery potential on both the RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on the RUN/ACC input).
  • Ignition switch OFF/LOCK position (absence of battery potential on the RUN, RUN/ACC, and START inputs).
The Trainer 24 Power Window Troubleshooting
Mar 03, 2017 | 1998 Lincoln Navigator
Peterbilt schematics
locate a positive wire that comes from the turn signal switch. You can open the switches on the steering wheel and trace the turn signal wires. once discovered, connect them to the two wires you discovered.
Jun 26, 2014 | Vehicle Parts & Accessories
Cannot do anything with camera go to take anything it says write protected
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 29, 2011 | GE X5 Digital Camera
Scan disk locked when opened incamera
If that doesn't work, try another card.
Mar 14, 2011 | Canon PowerShot A560 Digital Camera
Card Locked message is on my camera screen and I have not found how to remove it.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 07, 2010 | Canon PowerShot SD1000 Digital Camera
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
The recline on my power seat stopped working
I just bought a 2005 Nissan Altima that had the same problem. The motor was fine. I opened the switch and found that a trace on the small circuit board was cut/missing. I soldered it on the spot and it solved the problem. You can access the switch by carefully prying off the switch buttons, then the plate. There are two screws that must be removed so that you can pull the switch assembly out of the seat.
Jul 14, 2009 | 2003 Nissan Altima
Front seat locked in recline,
I just bought a 2005 Nissan Altima that had the same problem. You really can't bring the seat back up without removing the motor and manually turning the metal rod. The motor in my case was fine. I opened the switch and found that a trace on the small circuit board was cut/missing. I soldered it on the spot and it solved the problem. You can access the switch by carefully prying off the switch buttons, then the plate. There are two screws that must be removed so that you can pull the switch assembly out of the seat.
Jun 16, 2009 | 2005 Nissan Altima
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
