Question about Lenovo 3000 N200 PC Notebook
My Desktop Keeps restarting.....Can't get it to Start Windows
When i start the computer up, it goes flashes a lenovo screen
Then another one. then it goes to the regular windows startup thing and the green bar goes across but freezes. then it restarts and goes to this page with 2 choices
WINDOWS COULD NOT START
A Recent hardware or software change could have caused this
and it has ---
Fix Problem with Windows Computer Repair
OR
Start Windows Normally
I have tried both. the start windows normally option does the same thing I explained at the top.
The Repair option takes me to a lenovo rescue and recovery 4
when i get there it says pick your keyboard language..
I Pick english...
then it goes to pick what computer to fix
and no computers show up..
you can only click next..
so i do that
and it says
You Have to log in to do this. Please ask your computer administrator for help
IT SHOWS NO LOG IN SCREEN! :(
My Mom and dad have both tried fixing it and it still is the same....
PLEASE HELP!
Thanks
Why does my Lenovo cant start up windows.
Try to perform full restart, press power button down until computer shuts down (+5 seconds). Then try to restart it. If repair function is offered, do not select that, select "start up windows normally".
Apr 24, 2014 | Computers & Internet
Windows 8 recovery u330 touch
1 Press the Novo button to start the Lenovo OneKey Recovery system.
2 Click System Recovery. The computer will restart to the recovery environment.
3 Follow the on-screen instructions to restore the system partition to its
original status or to a previously created back-up point.
If Windows cannot be started, follow the steps below to start the Lenovo
OneKey Recovery system:
1 Shut down the computer.
2 Press the Novo button. From Novo Button Menu, select System recovery
and press Enter.
Oct 05, 2013 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My acer aspire one turns on, goes to the "were sry windows didnt start right" screen and regardless of which way i try to start it it flashes a blue screen really quick and reboots back to the "were s
You will need to run the recovery disk that you were advised to make when you first started using the laptop. This will re-install Windows form the System reserved area of your HDD.
Dec 16, 2012 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my computer everything is fine and then I get to a place that says "start windows normally" etc... And then when I click it it takes to me a blue screen with memory dump and then it restates...
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
Sep 10, 2010 | Lenovo 3000 G530 Notebook
My Lenovo SL500 laptop won't start up! When I turn it on, it runs perfectly until right after the Microsoft loading screen, when a blue screen with an error message pops up for 1/2 a second and then the...
hit the f8 key several times while it is rebooting and go the screen that allows you boot to windows, boot to last know good confifguration, boot to safe mode, etc... screen. On this menu you will find a selection that will allow you to stop the blue screen on the error. The error will tell you what the problem is. However from previous experience I can tell you that more than likely you will have to reinstall Windows. If you haven't backed up your data and need to recover it, It might be a good idea to setup the disk as an external drive or secondary (slave) drive on another computer, copy your data to a flashdisk or other backup device, reinstall your hdd as master/primary drive, boot to cd and reinstall windows. Have fun, let me know how it goes.
Aug 26, 2010 | IBM Lenovo ThinkCentre M55e PC Desktop
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo keeps rebooting from window showing safe mode or start normally mode, goes around in circles
When the computer goes into t eh boot mode click the F8 button. When you have a choice of how to boot check the "last known good version" of windows
Aug 14, 2009 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Lenevo Desk Top computer
your operating system has to be reloaded.
Jun 18, 2008 | Lenovo ThinkPad R51
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Lenovo 3000 N200 PC Notebook Logo
343 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
