Question about Kenmore Washing Machines
My Kenmore 587 won't fill with water. - Kenmore Washing Machines
    Top Expert:
  • Kenmore Master
  • 51,527 Answers
They have electrical inlet valves that do fail.
Posted on Jan 01, 2017
Kenmore dishwasher 587
It seems it is drain pump problem ,clean pump and try it and if problem persist you should replace pump if needed
Dec 09, 2013 | Dishwashers
Whirlpool washer model ICWTW474OYQO Type 587-08
My I have a whirlpool washing machine Model # WED4850XQ0, Type 587-08, it fills up with water, but when it start to agitate, it starts to smoke.
Jun 19, 2013 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
My Kenmore dishwasher Model @ 587-1511590 goes on but no water is comming out ?
Do you hear a 'click' when it is supposed to start filling the machine--if not, then the water inlet solenoid has likely failed. Make sure the water is turned on under the sink and there are no kinks in the supply hose. Hope this helps!
Sep 22, 2010 | Kenmore 15529 Built-in Dishwasher
Hi, I have a model 587 kenmore dishwasher which abruptly wont allow any water in right after I turn it on.
Assuming the water supply is on to the unit, check for a bad, stuck or clogged water fill valve. Some have a screen that can get plugged. You will need to turn off the water supply, remove the front lower cover, drain any remaining water out of the machine with a shallow pan, and then check the fill valve. You will probably have to remove it to do this. If you aren't comfortable with this kind of service, it's best to call a repair shop.
Another csue of this could be a problem with the dishwasher control board, but again, it's more advisable to have it checked by a repair shop.
Jun 07, 2009 | Dishwashers
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 587
I think you are right. That would be the most obvious answer. Some motors are warrantied for 2 years or longer.
Nov 02, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
