How can i program the remote to work properly the left arrow button changes that video on the tv and the down arrow turns volume to 100
    Top Expert:
  • Televison & ... Master
  • 74,666 Answers
It sounds that your remote control need to be cleaned. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Jan 01, 2017
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
Need code for urc-3605 for bell express vu satillite
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
Jan 16, 2010 | One For All URC-3605 Remote Control
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
I need 3 digit code for my Prima tv to program bell express vu
Dec 16, 2009 | Prima C2012 TV
How do I program a 1987 rca tv, lost the remote for it
if it is xl-100 "remote control" model (manu. 1987) I have a drop down door on front, there are names for buttons (5) at left:
auto pro,
step<
step > (arrows actually up/down)
add
erase
The other buttons to R are channel up & down, volume up & down & red Power, of course.
On the left, if you can "add" in some channels you scroll by, you may get more than 60.
(is this all moot, in 34 days, Feb 17)
My remote for another RCA does work some, for this "oldy."
Aug 25, 2008 | Televison & Video
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Code for satellite bell (expressview)
Jan 03, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
