How much time to charge - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 49,285 Answers
Until it is done but if the batteries are dead it will not charge
Posted on Jan 01, 2017
HBS-800 China made won't hold charge no more than 3 hours
Surly it didn't specify 79 hours of charge time did it? For 10 hours of operation the charge time should be around 20 hours or less depending on the charge controller device. I would hope it shuts the charging off once it senses the battery to be fully charged. Assuming all this is working as I've stated then I would conclude it is defective and seek to return/replace under warranty.
Nov 01, 2017 | Audio Players & Recorders
How long do you charge the cxt195 radios for the first time for the initial charge and after the first charge what about the next charge time is at same time frame
The initial charge time varies but overnight is generally recommended. Afterwards, the charge time is considerably less.
Dec 25, 2014 | Radio Communications
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
My phones charge finish quickly. Why
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 17, 2011 | Cell Phones
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? '
    Mar 13, 2011 | Acer Computers & Internet
    How long does it take to charge for first time
    8 full hours is recommended for a first time charge
    Jan 06, 2011 | Peg Perego 12 Volt Rechargeable Battery
    How long should i charge my 2500mah batteries for the firs time??? How long should be for 1350mah??? How long should be after first time???
    The first charge is - as you suspect - longer than the normal charge in order to "wake up" a battery that may have been on the shelf for a considerable time since manufacture. Typically 30 hours for the 2500mah batteries and 16 hours for the 1350mah.
    I assume that your charger charges at a rate of 140 to 160 mA. This info is usually printed on the charger itself. (Quick chargers is a different story and the chargers are usually intelligent and can regulate the charging electronically.)
    If your charger charges at a rate different to the typical 140/160mA, then increase or decrease the time for charging accordingly, i.e. reduce the charge time if the charge rate is higher. A good and safe test would be to check the batteries from time to time for heating. Stop the charging as soon as you find that the batteries are heating to anything warmer than a mild temperature rise.
    Jan 03, 2011 | Sony AA Nimh 2500 Mah Rechargeable Battery
    Charging new battery
    usually 8 hours.
    for first charge.
    on a brand new battery
    Jan 29, 2009 | IBM ThinkPad T41 Notebook
    Web cam installation, Charging & Flash problem.
    This modelnot charging good because i charge hole day but no more charging was happens. Flash is not ok some time oprate sometime not.
    Sep 05, 2008 | BenQ DC3400 Digital Camera
    I have a audiovox dvd player model D1998PK. I need to know how to tell when the battery is charged.
    1. A blinking light indicates that the battery is not charging.
    2. The steady light goes out (or turns green) when the battery is charged.
    3. 6 to 8 hours for the initial charge.
    4. Charging time after the initial charge depends on the length of time the battery was used and will increase over time as the battery gets older.
    5. 2.25 hours of play time
    Aug 23, 2008 | Audio Players & Recorders
    Computers & Internet Logo
    David Payne
    David Payne
