Question about Stanley Measuring Tools & Sensors
How long does it take to charge the Stanley pro amp 450 fatmax
  • 509 Answers
SOURCE: I cannot open the Stanley FatMax Retractable
Try this website and scroll down to product description...
Posted on Feb 01, 2010
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
  • 90 Answers
SOURCE: how to recharge stanley 450
There is a male 120V plug on it that you connect an extension cord to.
Posted on Jan 25, 2011
  • 3 Answers
SOURCE: I bought A Stanley 450
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Posted on Feb 15, 2011
  • 7 Answers
SOURCE: Loading instruction to change blade on Stanley
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video!
It's actually pretty easy! :)
Posted on Jul 31, 2012
Stanley Fatmax 450 Amp (Model J45TK)compressor starts and then stops right away. The charge is full showing the green LED light on.
You will likely have to open up the case to look inside.
The main components will be a circuit board, a 12v power supply, a 12v air pump and a 12v rechargeable battery. It sounds like a loose connection on the air compressor pump. When you turn it on it normally vibrates and is loud. This may be enough to shake loose a wire connection. If so it should be an easy fix to crimp or solder.
Aug 29, 2017 | Stanley Vehicle Parts & Accessories
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
Mar 04, 2016 | Measuring Tools & Sensors
Where can I download the instruction manual for a stanley fatmax 450 amp jumpstarter?
Request the manual directly from Stanley. It may not be available as a download.
Jan 12, 2015 | Stanley Measuring Tools & Sensors
How can I tell when my stanley 450 amp instant starting power station is fully charged?
I would suspect that the internal battery has reached the end of its life. Surely there is a green light to indicate when it is charged?
Jan 06, 2015 | 450 Amp Battery Jump-Starter
How can I get a parts repair manual/list for a stanley fatmax 3.8 cfm compressor
try searching for stanley fatmax compressor . I think bostitch owns it
Nov 03, 2014 | Measuring Tools & Sensors
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
Stanley fatmax 450
Open up the case and look inside. A wire may have come off.
i had a brand new compressor that wouldn't power on. A wire was not connected. After reconnecting and a positive testing I put it back together. It ran for five minutes and stopped. It turns out the wire was too short (factory install) and came disconnected each time the compressor was turned on due to the vibration. I rerouted the wire so it wasn't so tight. Problem solved.
Oct 29, 2013 | Stanley STA-J45C09 450 Watt Jump Starter...
Measuring Tools & Sensors Logo
179 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
