I will really be glad if you can help me.When i turn on my home theartre system, 2 or 3 of the tweeters make a 'pop' sound, like they have burst or something, then the dvd player itself goes to dvd/cd mode and all the buttons stop functioning exept 'off'.Even when i turn it off it the speakers make a funny sound.
I have tried everything, including disconnecting the speakers that make the 'pop' sound when i turn it on but it still doesnt work!This system is less than a year old so i wonder why its acting up like this.It has diminished my confidence in LG products.PLEASE HELP!!!
SOURCE: LG home theatre system model LH-T1000
Hi I have the same tv. How is the video signal coming out of the dvd player and what is it plugged into on the tv. I travel for a living and coach my wife over the phone all the time.
Posted on Sep 17, 2007
SOURCE: No Digital TV Picture LG DAT-250 DVD Home Theater with Digital TV Receiver
Did you check PAL/NTSC settings?
Posted on Oct 01, 2007
SOURCE: T5420 unable to transmit or receive. Please help!
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Posted on Aug 24, 2008
SOURCE: resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Posted on Jan 02, 2009
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Posted on Apr 24, 2009
Apr 12, 2011 | Televison & Video
on Jul 14, 2010 | Televison & Video
Jan 02, 2009 | LG LH-T754 Theater System
on Jul 14, 2010 | Audio Players & Recorders
on Jul 14, 2010 | LG LH-D6230 System
Jan 16, 2008 | LG LH-D6230 System
136 people viewed this question
