Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
My drive has stopped working. There is +11.75 volts from the power supply, checked with a digital mumlti meter, and the 'power on' led is lit. I cannot hear any sounds of a disc rotating from within the unit.
  • chris_robins Aug 05, 2009
    I am happy to report this problem is now solved, despite the power supply showing +11.75v, I substituted it and hey presto, the drive is now working.
  • 60 Answers
Try taking the disk out and putting it in a new enclosure of your choise.
Posted on Aug 02, 2009
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
There is sound but no picture. No backlights but can see a picture in dark with flashlight test. LED panel # is D460D3-6Y43-COX. What part would I need to purchase? T
You have check the power supply first .To know how to check the power supply watch the following video. Normally led tvs power supply contains the led drive circuit too. Bot are integrated in the same board. The led drives circuit should have between 30 to 120 volts from the power section depending up on the brand and model number of the TV. If the the voltage is ok then you have problem with the Led driver section section. Either you can try to repair it or can buy a new power board.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | SEIKI Digital SE46FY10 46" LED TV...
The board will not turn on
If the board has a power led then check that is lit.
The first power on self-test (POST) will beep when complete or give you beep codes if there is a detected failure.
If you have a good power supply (+5 volts and 12 volts) and a lit power led on the board and there is no POST beeps at all then that generally indicates a video problem.
Oct 18, 2014 | Intel Computers & Internet
D-link router (with 1 antenna and no modem) that has no power and no LEDs lit. the outlet still works to charge a cellphone. how do we fix the router?
Possibly the powersupply for the router is dead. Find another powersupply with same voltage output to try OR test the output tip with a meter. If the power supply does work then your router is dead. Replace it. If there is no power (5 volts or 12 volts etc) coming from the tip of the power supply adaptor then replace the adaptor / power supply.
Apr 28, 2013 | Computers & Internet
My tv just stopped working i turned it on and it clicked like it was going to come on but it did not i changed the fuse in the back of the tv and still nothing it is a model number dp32746
first check the power supply secondary using digital volt meter, there should be 12volt dc for drive circuits, and 120+ volt dc for horizontal output, but if the horizontal output is shorted, 120+VDC will just fold back, so check the Horizontal Output also.. hope this helps ;-)
Feb 03, 2011 | Sanyo DP32649 31.5 in. TV
My mixer wont power up. the only light that comes on is red led +48 v
This MAY be a power supply problem. We need to find if the power supply is putting out what it is supposed to. Using a meter, put one probe in pin 1 (ground) of one of the mic connectors, say channel1. Put the other probe in either pin 2 or 3 of another mic connector... Note we are using different connectors as there often isn't enough clearance for the probes in the same one... With Phantom power turned on and LED +48 lit, how much voltage do you read? If it is say 40 volts or more, then power supply is operating.
If the supply is operating then a POSSIBLE problem is a connector has fallen off where it connects to the supply or the main board.
The power supply provides several voltages such as 5 volts, 12 volts and 15 volts of various polarity.
If the 48 volt supply is found to be operating with the above test, then since the switcher and transformer are shared, it is likely the other voltages are available.
CAREFULLY open the unit and look for a loose cable.
PLEASE NOTE: This is a switching type power supply and part of the supply runs at power line potential. Only work on the supply if you are skilled and have an isolation transformer for your own safety.
Sep 21, 2010 | Behringer XENYX 2442FX Mixer
Power to Motherboard but will not bootup?
most likely a failed hard drive as all of the boot requirements are on it
Apr 24, 2017 | MSI 694T PRO (6309-470) Motherboard
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
204 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
