Ion says menu to reset corrupted playlist .Tried hot keys and menus nothing responding.
3 Suggested Answers
  • 37 Answers
SOURCE: corrupted playlist... hdcd to reset... tried that.. doesnt work
Either the HD is bad or you will need to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
hope this helps
dave
Posted on Jun 24, 2009
SD Tech
  • 14553 Answers
SOURCE: When my tv is powered on, it displays the device menu and continues scrolling through it, but will do NOTHING else. I've tried to reset, and nothing. The tv will not respond to the remote at all.
A suggestion here: If possible to remove front speaker grill and inspection plate that should be behind it---locate the bundle of wires that comes down from front keyboard with the buttons and follow it to the right and down---should be one or two plugs in-line--------disconnect them with the set off and power set back up with remote.
If the problem is gone you have a bad micro-switch on the front of the set------buttons on the keyboard there have priority over the remote---hence you cannot if the problem is there stop it with the remote or do anything for that matter.
Let me know what happens and I will suggest options.
Posted on Jun 01, 2012
What do I do when my acer r-1600 will not respond to the " F12 " button instructions?
what function does the F12 button do? maybe the program you are using doesnt make use of this function key, in which case nothing will happen. do other function keys work OK? maybe you need to push a Fn button as well to activate the F12 key. have you tried a different keyboard?
Oct 19, 2014 | Acer Revo Ar1600 Desktop Atom 230 1.6 Ghz...
ZTE Z990 when hard reset it says failure. package corrupt. How to fix?
The solution of your ZTE hard reset problem:
http://www.hard-reset.com/zte/
Jul 15, 2012 | ZTE Avail-Z990 Avail At&t Unlocked Android...
When I turn it on, it says " System error -
you might need the os in order for it to work properly. i dont use Ion and not a big fan of them. but if they said try installing the OS try it again and maybe see if theres a system reset.
Apr 29, 2011 | ION Audio LP 2 CD Turntable
Corrupted playlist... hdcd to reset... tried that.. doesnt work
I had the same problem.....but reading your post helped me with my corrupted file. I just powered up like you said and immediately held the create cd button and utility button. I held it until the formatting was finished. problem solved....but lost some music in the process. Charlie Woo.
Feb 04, 2009 | Alesis MasterLink ML-9600
Ion lp2cd turntable error mssg
My system is an LP2CD It is bloked on
MENU TO REST
CORRUPTED PLY 1ST
Could you help me
many thanks
daniel ajzenberg
Dec 28, 2008 | Audio Players & Recorders
Internet explorer menus not showing
try to press Alt key on internet explorer window...
Dec 10, 2008 | Microsoft Internet Explorer 7
I can't reset my GPX 1 gb device
both of you have to do format your mp3 player
because sometimes it not deleting
so just format your device by going to my computer
and right click on it
and format it
and fill your new playlist
Aug 17, 2008 | GPX MW3337G
Can't reset
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 23, 2008 | Texas Instruments TI-83 Plus Calculator
Megellan Roadmate 700, touch screen not working, if it works takes too long!
Mthomas, Although I can't think of any quick fix, if you have a cd of the software version that you've installed then try re-installing that. if nothing else, access the secret " " menu and reset user data, you'd be amazed at how much that can fix at times. At user menu (after reset) press "-" and repeat key at the same time. select "reset user data". If you can get it to the touch screen calibration test, then it could respond. (eventhough it's not working otherwise) Good Luck, DanEz007
Dec 12, 2006 | Magellan RoadMate 700 GPS Receiver
 Grubhead
Grubhead
