Question about Dryers
I changed the thermal fuse and thermistor and still getting E1 code after about a minute of running. If I put it on air only it will stay running but anything eles even low heat shuts off
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Check your vent make sure it is clear disconnect it from the back of the dryer and try to run it then if it works you have a bad vent if not and you have a new thermistor try timed dry see if it works on that if it does it may be running to hot on automatic cycles so may be the computer or bad wire some place
Posted on Jan 01, 2017
  • 1723 Answers
SOURCE: Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Posted on Jul 22, 2009
  • 6784 Answers
SOURCE: Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Posted on Aug 12, 2009
  • 103 Answers
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
  • 15935 Answers
SOURCE: Whirlpool duet electric dryerGEW 9200 L --no heat
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Posted on Sep 30, 2010
Dv210aew/xaa THERMAL FUSE keeps blowing after replaced 3 times. Cleaned out exhaust and replace heater element and thermostat switch, what else can it be the problem?
on the blower housing there's a thermistor that takes the place of the cycling t-stat,if that's not working correctly the dryer will run to hot or not hot enough,also check the duct that the lint filter slides down into,make sure that isn't clogged with lint,then run the dryer with the vent line disconnected to make sure there isn't anything blocking it,how long is the vent line?if it's a long run i stick a leaf blower into it and blow the stuff to the outside,you should take the dryer apart and clean it at least once a year and blow out the vent line so things like this don't happen,part number for thermistor is DC32-00007A.what thermal fuse are you changing there's one on the heater box and one on the blower wheel housing if it's the one on the blower wheel housing you could still have a block in the vent line or a thermistor problem,if it's the one on the heater box you could have a bad high limit that's the t-stat next to the thermal cutoff on the box,one more thing when you changed the element did you buy the whole part with the t-stats,if not if you ever have a problem with the element buy the whole thing you get the element and t-stats together and you just pull the wires off and change the whole heater.if the vent isn't clogged and you changed all the t-stats and it still pops you could have a bad computer board,do this,when you change the thermal fuse,start it with the vent line disconnected,put it on air fluff and start it,if the heater comes on the element is shorted one of the coils are touching metal,if the heater doesn't come on run it with the vent line still disconnected and see what happens,those t-stats are pretty reliable but one could be bad but the board could be the problem but the dryer is running to hot and popping the thermal fuse,use a watch to time it,when it starts with no clothes the heater should stay on for no more than 3 to 4 minutes,then it should shut down,for a minute to a minute and a half and come on again but now it should only stay on for like 50 to 60 seconds and shut down.sorry to make this answer so long but without being there i'm just trying to tell you what i would check.let me know what you find,keep an eye on how long the heater is staying on if you think it's on for to long while you're checking it stop it and put it on air fluff to cool it down so you don't cook the thermal fuse again
Oct 07, 2017 | Dryers
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dryer runs for 1 min. and then shuts off with e1 error, I did some research and found out their is a thermal fuse located behind the lower panel. Also something about a the heater could be...
E1 error code is a problem with the thermister sensor is is located behind the lower front do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Aug 22, 2010 | Whirlpool GEW9200L Electric Dryer
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
E1 code - what is this?
I cannot get your model number to come up, but in general the error message you are getting is usually associated with a bad thermistor.
A thermistor is an electric device whose resistence changes as the termparature changes. In your dryer it is sited in the exhaust air vent and monitors the temperature of the exhaust air. This allows it to help control the thermostat so that your dryer runs at the correct temperature. When it goes bad you get the E1 error.
Here's what I would recommend. First take off the bottom panel and you should find some tech notes and trouble shooting info. Go through any troubleshooting routine and confirm the E1 error is associated with the thermistor. The tech notes will probably have a way to test the thermistor if you want to confirm a diagnosis.
If it is the thermistor, remove the vent cover and replace it. It comes off with two screws so it is a pretty easy job.
Good luck, let us know what you find out. __________________
- digg.gifdelicious.giftechnorati.giffurl.gif quote.gif Find all posts by sidfink43
Jul 22, 2009 | Kenmore Dryers
Calypso Dryer thermistor replace
if e1 is thermistor code remove bottom panel look behind lint screen housing should be a black oval object with 2 wires just behind housing and to the right of the white thermal fuse
Sep 03, 2008 | Dryers
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
