Aren't Heat n Glo fireplace doors meant to closed when in use ? Our doors tend to smoke up?.
3 Suggested Answers
  • 24 Answers
SOURCE: I have a heat-n-glo gas
replace thermocupple from gas valve to pilot light.
Posted on Sep 04, 2010
  • 242 Answers
SOURCE: Heat n Glo gas fireplace pilot doe not stay lit
Posted on Oct 17, 2015
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
I have a heat & Glo XLR Plus. This is the first time I have used it but when I turn it on, the flame burns for around 30 sces then goes out. Then after about 30 secs it comes back on.. then off and so...
On your hand held remote [check your remote's owners manual], there is a mode setting for thermostat. This allows your remote to act as the thermostat for the room. It is in this mode and the temperature is set close to the current room temperature. Turn this mode off. Do not use this mode. Obviously you do not have the required experience to use it. It will come on and off even when you are not home. Again, until you become a lot more familiar with the setting, turn it off.
Mar 08, 2015 | Heat and Glo GFK-160A Blower Kit for Heat...
My vented gas firs place keep gping into flame lift off. Hos do i fix this flame lift off. My gas log pro says i have to take the box out.??
I would suggest looking under the bottom louver of your fireplace as you have a b-vent or direct vent gas fireplace. From the looks of it alone it appears as its an early model Heat-N-Glo fireplace. If you flip down the bottom panel, where the two gold strips are at, underneath the gas valve you will find a sticker or a plate that has the model, manufacturer, and serial number. I work for a manufacturer that has been in the fireplace business for over 30 years and I'm betting $10 to a donut that is a Heat-N-Glo fireplace. Once you get the model, manufactuer, serial number, and date code sometimes you can search at for AUTHORIZED dealers who can service your fireplace properly instead of a chimney sweep who may or may not be qualified to "trouble shoot" what is going on with the fireplace. It looks like an 8000GDV to me.
Best guess is a new pilot assembly if its a direct vent. If its a b-vent then a high limit switch might be needed as well with it cutting off that fast. It also could be a flue disconnect. Long story short I would find out the model, manufacturer, and then get on the manufacturer's website or call them to find out an AUTHORIZED servicing dealer for your fireplace. I hope this helps.
Apr 08, 2014 | Home
Fan working hot air not coming through front vent
One, is there any air at all coming through the top vent? If not schedule a professional service call with a local reputable company. You may have a blockage. If there is air coming through and it is cool, try letting the fireplace warm up for about 15 minutes before trying to run the fan. The fan can only blow hot air after the fireplace gets hot.
Feb 08, 2014 | Heat and Glo GFK-160A Blower Kit for Heat...
Gas fireplace manuals
There are two things that control flame height gas volume and air volume. Some fireplaces have a flame control knob on the gas valvd to adjust flame height. Air volume is controlled by an air shutter usually located where the main gas orifice enters the burner. There is usually a small cover that will need to be removed to access the shutter. Closing the shutter will cause the flames to become taller and more yellow colored. Closing the shutter too far will cause sooting problems so great care should be taken in adjusting this shutter.As a rule, L.P. gas fireplaces do not have as high of a flame as natural gas unit do.
Hope this helps
Dec 14, 2013 | Heating & Cooling
Fireplace remote not working properly
I'm not sure if you have found a solution to your problem yet, but if you would like to provide some additional information about your problem, I'd be happy to help.
If you are looking for a replacement, I have them available here: Smart Stat Remote for Heat-N-Glo.
Jan 01, 2013 | Skytech Smart Stat Fireplace Remote for...
Owners manual heat-n-glo smart-stat
Try searching through this:
Nov 11, 2012 | Skytech Smart Stat Fireplace Remote for...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
