Question about Apple MacBook Air
No internal sound system found
Hey there, me too,having the same problem now..tried all the solutions found online be it paperclip,toothpick,plastic pen tube,wriggling it,restart it back and more.. im getting tired of it and afraid that bringing it to apple store will be very expensive!!! =(
the red light in the headphone hole is suddenly on and i can only hear the sound with headset plugged in.
hope u guys could help!thank u so much.
  • 160 Answers
Have you taken a peek in system preferences sound? what are your settings there? have you plugged into external speakers?
Posted on Jul 24, 2009
Pls l have try the reset don,t work what wil l do now
Toothpicks are tapered, and might not go far enough in the hole to fully depress the reset button.
Try the end of a paperclip instead, that is the tool the hole and switch were intended for.
If you try jamming the toothpick in further, you run great risk of having it bust off in the hole and really messing things up.
Jan 23, 2015 | Computers & Internet
Lumix Camera won't read sd card at all.
I have the exact same problem, have not found a solution yet.
Apr 22, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
Evon610c keyboard keys broken how to replace the keyboard ? how to open the case with out damage internal parts ??
Hi
this may help you i found it somewhere online
How to Replace the hp compaq evo n610c laptop keyboard Removing the Damaged Keyboard
Enusre the laptop is fully powered off, unplugged from the wall, and the battery taken out.
Turn the laptop over. On some models icons indicating which screws are attached to the keyboard are displayed. If not, you may have to eyeball it if you can't find a breakdown for your model online.
Remove those screws with a Phillips screwdriver.
Turn the laptop back over and open it up. Check and see if the keyboard is tucked under any plastic pieces. If so, find if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
Remove the plastic pieces carefully with a toothpick or plastic pick if there is any in the way.
Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
Take that same pick and lift the plastic connectors that hold in this data cable in place.
Carefully remove the data cable. Now the whole keyboard should be free.
Replacing the keyboard
Take the new keyboard out of the plastic, and slip the data cable back in between the plastic connectors on the system board. Make sure it's all the way in.
Use the pick to push the plastic connectors back into place, and make sure it's holding the data cable in.
Slip the keyboard itself into place, from bottom to top. Make sure the screw holes or clamps line up at the top.
Refasten the keyboard in place at the top.
If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
Turn the laptop over and replace all of the keyboard screws.
Finally, put the battery back in and power on the laptop. If all has gone well, the keyboard should be functioning like brand new
hope this was helpful
Jun 21, 2011 | Compaq Evo N610C Notebook
My new Yamaha HTR- 3063 says decoder off and I cant get any sound how can I fix this
Hey I am having the same issue. I hope you found a solution..if you did PLEASE let me know..you can email me at bbv5858@gmail.com
Thanks in advance
Jan 30, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I can not sync my Controller to my ps3 console. I tried using the USB cord and it will not connect. I purchased a brand new controller and still the same results. What am I missing?
Easy fix! Here's what you do:
Start with everything off, connect your PS3 remote to the cord and plug it into your PS3.
You are going to need something pretty thin, like a pencil lead, toothpick, or something semi-pointy with a decent size tip. I use a paperclip.
Turn your PS3 on by hand, running your finger over the power opening (Don't know the technical term for this hole...) and let it completely boot up
Once your main screen is loaded, press the center PS button on your remote. The 4 red lights will start flashing. Take the pointy end of your (paperclip/toothpick/other pointy object) and insert it into the tiny hole on the top back of the remote, press it in like your pushing an internal button. It should be right behind the 4 red lights - either way - it's the only little hole you have on it. Hold it in for a few seconds.
The controller will process, and if done correctly, will sync with your PS3.
If you have any other problems let me know. Enjoy!
Respectfully,
Don
Oct 26, 2010 | Sony Playstation 3 (PS3) Console
On/off button stays in. won't work
Cheaply made part that is non-replaceable. One solution is to drill a small hole just to the left of the power button big enough to insert a toothpick through. Power can be turned on and off with the toothpick. Can use a paperclip but it will scratch up the bezel on the outside and the circuit board on the inside.
Jun 12, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
My matSHITa dvd-ram uj880es drive wont work.
There is a small hole in the drawer to poke a paperclip, or toothpick into and open it manually. Have you tried to see if there is a cd or something jammed in it? Or try to update the driver in the control panel system.
May 17, 2010 | Computers & Internet
RESET didn't work
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player. If this does not work, I suggest that you reformat the player by using the Windows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device.
Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Dec 02, 2008 | RCA OPAL M4001 MP3 Player
Sound - internal speakers (MacBook Air)
I have a solution for you all.  This fixed the problem for me.  First, make sure you are all running 10.5.5.  If you are not, run software update from the Apple Menu.  If you are set there, go to Applications --> Utilities --> Disk Utility --> Make sure your Hard Drive is selected on the left hand panel --> MAKE SURE the First Aid tab is selected! --> Click Repair Disk Permissions.  This may take a while, FYI.  As soon as Disk Permissions have been repaired, restart your computer right away.  That fixed the problem at my end.  Good luck everyone!
Sep 17, 2008 | Apple MacBook Air
HP DVD WRITER 840b - CD/DVD Tray won't open??!!
Problem of tray opening on hp dvd burner. I got the door open as suggested above with paperclip. Then took some CRC 2-26 plastic safe electrical grade lubricant and swabbed the pivoting door mechanism. Opened with the paperclip about 5-6 more times until it finally opens normally.
Feb 28, 2008 | HP (176135-630) (176135630) Internal 48x...
Apple MacBook Air Logo
142 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
