Question about Baby Gear
The isofix fitting on one side of my Kiddicare shuffle car seat is jammed. How can I get it to extend out?
  • 3 Answers
SOURCE: fitting cabriofix car seat with seatbelt only
yeah i had a cabrio and just fitted it in car with the seat belt the part of the seat belt that would go around your waist goes over the front of the carseat and over were the baby would be sitting there is clips at either side just below the carryhandle put the seat belt through them then put the part of the seat belt that would go around your neck round the back there should be another clip in the middle of the back above the storage part if you put the seat belt throgh it then clip the buckle in and pull tight the car seat should be secure hope i explained it easy to follow.
Posted on Nov 03, 2008
Babycare_nl
  • 21 Answers
SOURCE: maxi-cosi priorifix - fitting with seat belt
Sure!
Please download the manual via this link.
The instructions are on page 10, paragraph D
http://www.maxi-cosi.nl/media/producthandleidingen/maxicosi/PrioriFix.pdf
With kind regards,
www.babycare.nl
Erwin de Raad
Posted on Jun 24, 2009
  • 419 Answers
SOURCE: Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Posted on Sep 15, 2009
SOURCE: how to use recline function for britax kidfix seat?
A bit late to reply, but check out the video here;
http://www.britax.co.uk/car-seats/kidfix
Recline only works for ISO fit, basically put your hand into seat slot and grab the handle, push/pull to recline the seat
Posted on Jun 05, 2010
  • 286 Answers
SOURCE: Can a maxi cosi cabriofix
hi yes you can here is a video showing you how to fit in a car
http://www.youtube.com/user/Kiddicare#p/search/17/vO51Ev2c2Ok
Posted on Feb 17, 2011
Chicco Oasys 1 isofix connectors jammed
Please contact Chicco for assistance
Chicco UK Home
Oct 16, 2014 | Baby Gear
How do I remove the Bambino Elite Isofix car seat from my car?
I had exactly this problem! First I could not find my user manual, but luckily Bambino provides it online. Then you discover that removing the seat is not covered in the manual... (Bambino, take note!)
I eventually figured it out (the items in bold are mentioned in the manual):
- Remove the top tether (the strap that goes over the top of the seatback and clips in behind the seat).
- Rotate the adjuster buttons (2 knobs, one on each side of the car seat near the bottom) anti-clockwise so that the ISOFIX anchors can extend. The seat will now be loose but still clipped in.
- Pull both release buttons (small sliding catches on the ISOFIX anchors, close to the red+green indicator) towards the front of the seat so that the ISOFIX indicators turn red. The seat should now be free!
Sep 18, 2014 | Baby Gear
Can you retro install Isofix in a 09 reg x type jaguar estate
Not in the United States. But if you have a seating position in the car, you may use the seat belt to install the seat. There is no safety difference between using the seat belt or ISOFIX/LATCH.
Note: Not all child seats fit in all cars!
Jul 06, 2014 | Britax Baby Gear
Why is the bottom of the isofix base is not level with the seat?
Hi Andrew
It is not possible to diagnose without inspection.
Was the unit approved for use in your vehicle on our online fitting list?
Was the unit physically fitted by a carseat fitter trained member of staff to confirm suitability prior to purchase?
Please contact us with further information so that we can best assist.
Dorel UK Customer Service
May 11, 2014 | Maxi-Cosi Familyfix Base Isofix only
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
The yellow anchor points that attach to the car fittings and then the isofix base fits on to them. where can I get 2 more
If you mean the plastic caps that click onto the isofix points in the car, then you can buy these on eBay, just search for ISOFIX GUIDERS.
I hope this helps.
Sep 26, 2009 | Maxi-Cosi Priori
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
Fitting an isofix car seat in a ford cmax 57 plate tdi
if there are a small part of the backseat (ca 10 cm high located at the bottom of the back) that can be picked out, you have isofix points.
if your backseats are in one pice, theres not
Apr 11, 2009 | 2007 Ford Focus (3 Door) Hatchback
Moving maxi cosi to another car
I assume that you mean the Maxi Cosi Priorifix?
At the top of the leg (that extends to the floor of your car) there is a button (which, if connected to the Isofix points will be red) push this button in as far as it will go and the seat will release from the Isofix points.
I hope this helps.
Jan 25, 2009 | Maxi-Cosi Priori
Baby Gear Logo
54 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
