Question about HP Color LaserJet 4550 Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
Paper runs through when a print job is sent, but nothing appears printed, no cyan, no magenta, no yellow, no black. Same when attempting to print a Configuration page. All 4 toner cartridges appear ok. There is no "error" message on the screen - it reports "ready". I am unfamiliar with toner and fuser cartridge replacement. Someone else in the office may have attempted to change the toner and/or fuser more recently, but cannot get history.
    Scholar:
  • 71 Answers
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Posted on Jul 21, 2009
49.38.07 error
Best way to test this issue is to unplug from the network, power off machine and back on then see if the error comes back. If it does not then try some internal test prints, if they print OK there is a corrupt print job being sent to the printer causing it to have the 49 error code.
I would clear all print queue jobs then upgrade firmware, this should fix it, printing from some websites cause this error, try another brouser if possible, Chrome etc.
Aug 24, 2014 | HEWLETT PACKARD - LASER JETS CE708ABGJ...
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
HP Laser Jet 4350tn issue
open tray 2 and tray 3 and try it.
Dec 03, 2007 | HP LaserJet 4350TN Printer
Hp color laser jet 4700n
Go to the paper menu set tray 1, Letter size and "any" for paper type.
Set tray 2 Letter and paper type "Plain"
Oct 10, 2007 | HP LaserJet color laser printer
HP Color LaserJet 4550 Printer Logo
488 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
