Question about Cobra Radio Communications
I HAVE JUST GOT A PIEZO-DX-357 CB RADIO BASE MIC WIRING IS BLUE YELLOW WHITE SCREEN AND RED WOULD LIKE TO WIRE IT TO MY COBRA 148GTLDX BUT DONT KNOW THE WIRING CAN ANYBODY HELP THANKS
TRIED TO WIRE IT TO MY COBRA BUT CAN ONLY GET KEY UP BUT THE MIKE HASE A SWITCH ON THE UNDERSIDE WHICH SAYS ELECTRONIC ON ONE SIDE ANDRELAY ON THE OTHER SIDE HAVE TRIED DIFFERENT WAYS WITH THE WIRING BUT HAD TO GIVE UP CAN YOU HELP THE MIKE IS FROM THE 90S
SOURCE: CB MIcrophone RewireJob. A Diesel Model 360-100 to cobra's
does it have a sheld wire?
Posted on Jan 14, 2009
tparsenault
  • 170 Answers
SOURCE: mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
Posted on Feb 10, 2009
  • 5 Answers
SOURCE: wiring of turner dm 7800 base mike [ old
hello i have now got the problem solved thanks to your team very fast response thank you 54 alex
Posted on Aug 02, 2009
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Posted on Nov 23, 2009
  • 41 Answers
SOURCE: i have a general lee
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Posted on Jul 12, 2011
Need Cobra 148GTL with Cobra HG M75 pin-out color code
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a uniden grant xl the older one. i have spent 36 hours looking for a wiring for a m75 cobra power mic and have tryed lots and none work. i cant even get wiring for a stock[ cobra mic red white
it doesn't make a difference what color wire it is as long as the wire is connected to the function it is going to control If your mic has a red , blue , black , and shield wires but your radio isn't set that way you have to set it to the way your radio is . you have to find out where ground is then audio in and audio out then the last is the shield.
Jun 10, 2012 | Cobra Radio Communications
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
I have an older cobra 19 dx the mic cord got pulled out its a 4 pin ther is a purple,red,black with yellow and a bare wire i would like to know wich one goes where?
On the Internet search "Cobra 19 mic wiring" and you'll get lots of hits with wiring instructions for various mics used on that radio. You will need some soldering skill to put it back together. Also use shrink tubing to seal it up afterwords so no unshielded wires appear outside the wire clamp. There are lots of compatible 4-pin Cobra mics at CB shops and truck stop shops.
Feb 19, 2011 | Cobra 19 DX II 40-Channels Base CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Mic wiring for a cobra 85 base cb
Jan 08, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
56 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
